Let's see your toolbox.
gaffobohs
Calgary, Alberta
Man I hate the VT365s! Had two in the shop in the last two months. Both non starts. Ended up narrowing it down to being the fuel/PS pump. And then got the new one back on and still no start. Took the brand new fuel pump back off and found a seal in 3 pieces inside the pump:mad:
Then the other no start ended up being a previous tech who doesn't work there anymore changed #2 injector but pinched the seal going in so so it was passing combustion gasses past the injector.
We have over 300 busses in our fleet. 444e's, VT365's, Maxxforce, DT466, 5.9's, ISB 6.7's, ford and GM vans. Lots to keep us going!
joedodge
Tampa, fl
We've got a range of everything from 3126 cats, c7 cats, mb900e, a tong dt 466, and maxxforce dt, cummins 6.7. We chew up egr stuff hp pumps and ipr valves, def system stuff were constantly cooking dpf and cats, injectors you name it. Are you guys full service shop?
gaffobohs
Calgary, Alberta
Yeah we got about 65 buses and 20 caravans. And we have a lot of egr coolers and ipr value problems on the vt's and alsos changing injectors . The old t444 we have are bullet proof. And the maxxforces been good also. I guess next year you can get the cummins 6.7 in The IC buses but we are holding off on those because of the DEF but I herd the maxxforces in 2015 have DEF also. The ic buses Arnt built like the old blue birds that's forsure.
We've had major problems with DEF in our new C2 Freightliners. Our busses do a mainly in city routes so not much highway miles so we get a lot of derates. This winter a lot of them have had the suction line from the tank to the pump break off right at the fitting. Also doesn't help when drivers fill up the DEF tanks with diesel :dunno:
gaffobohs
Calgary, Alberta
Ahh man that ***** we do Ll the def filling in the shop drivers aren't aloud
Oh we do too. When they are at the filling station I guess they just see DIESEL exhaust fluid and fill it up. Maybe they think its a reserve tank:lol_hitti The giveaway is when you look in the logbook and see 120ltrs + 20ltrs:lol_hitti
Agentwho
Baltimore
A few weeks agoe I saw this Craftsman Profesional 32" box listed on Craigslist for 200 bucks. After some slow emails I got it last weekend. The guy hadn't opened the box for a while so the first thing we see in the top drawer was a mouse nest and a tail scurry down to the next one. We chased it all the way down like that n had to pull the bottom drawer out to evicte the little guy lol. Cleaned the mess out and loaded her up
The box is nice, it's a lot better quality than my other craftsman griplatch box. Good heavy construction, no slop in the drawers and handles the weight. I'm really happy with it, now I just have to get use to the new tool layout. "Are the air tools in the 3rd or 4th drawer" :)
Jon.R
Ontario Canada
Yeah we had a vt no start this week had no oil pressure so we thought the nut on high pressure oil pump mayb backed off or the o ring came out , we had happen befor. But it ended up being the high pressure oil pump was gone on it. The bus dealer here in Ontario "Leeds" said it was the first time they herd of a high pressure oil pump going on a vt .
gaffobohs
Calgary, Alberta
Ha yeah right i've seen lots of them both on VT365s and ford 6ltrs. Theres a good test you can do to see if that HPOP is leaking as it seems to be a common failure point at the branch tube fitting where that nut is. You can get an adapter that screws into the where the ICP valve goes and you hook your airline up and listen for leaks.
joedodge
Tampa, fl
Can't count how many I've changed in vt,60!!! I made my adapter. Works every time to tell you where your air leak is
gaffobohs
Calgary, Alberta
Anyway back on topic took some pics after I finished up yesterday. Eventually want to get a better box with deeper drawers but this does me for now.
gaffobohs
Calgary, Alberta
If the drawer layout was better i'd be a lot happier as there's a lot of wasted space but it was $700 new so couldn't go wrong! Yeah the locker comes in quite handy!
richfinn
Leeds, Yorkshire, England
I originally come from and still work in a place called "Leeds" in the UK, I googled "Leeds Ontario" and it takes it name from my home city.
Got any pics of what it's like?
We have have a few "claims to fame" if your interested :)
DieselRiver
Madison, WI
I just reorganized my entire toolbox around, let me know what you guys think. FYI, i clean my tools off every time before they go back into the toolbox. My tools do get used i just take care of them. The bottom 2 drawers of the bottom box are mostly filled with extra tools/junk.
<iframe width="640" height="360" src="//www.youtube.com/embed/9x7YI8wN8QY" frameborder="0" allowfullscreen></iframe>
alpinewhite
Orange County, California, USA
I can't see pics
young_buck
Alberta, Canada
Well I guess i should get on the drawer pics i promised a week ago.. I am adding to it as i go but this is my collection.
My box the day I got it home, $600 well spent! 56" mastercraft Maximum roller
Top drawer, sockets and ratchets/torque wrench's
Pliers and pullers
Misc, flashlights, picks
Taps/dies, micrometer
Screwdrivers
Adjustables, pipe wrenches, punches/chisels, brake tools, 3/8s impact sockets and my snipe
Wrenches, well most of them all my custom made and specialty wrenches reside in my other box in the rolls are my 6-20mm and 1/4-1 1/4 plus i have 22-27 and a 1 3/8 outside of the rolls, and on the racks are gearwrench's
hammers and prybars
fuel pressure tester, 1 1/4"-2" impact sockets in blow mold case, 3/4" drive ratchet, breaker bar and sockets, multimeters, circuit tester, torque angle gauge and some other odds and ends
Power tools, air tools and accessories my 1/2" impacts aren't in the drawer, one is on my bench from changing my buddies tires last night and the other is being rebuilt
Also the other day I decided to make another purchase I've been wanting to make for a while now
Ill also throw this in, this is my current project. A 76' 350 small block awaiting a new cam, rings, rocker arms, edelbrock air gap intake, long tubes, edelbrock 4 barrel carb and a fresh coat of chevy orange :thumbup:
It is getting bolted to a turbo400 and being dropped into an s10. :3gears:
When I am done that project I am moving on to my 5.3 LS swap into a gmt400.
Not too bad for 17 if I do say so myself, especially for not being funded by my parents. I can proudly say that at least 80% of my tools were bought by myself and the rest were gifted to me on christmas/ birthdays. I am working as a heavy equipment technician through my highschool right now and most of what I earn goes towards my tools and my passion. I loo forward to having something similar to the snap-on setups that some of you guys have,
ihateminimumwage
I like that setup.:thumbup:
I thought it was one of the cheap Husky boxes for a second, but it's wider has more drawers, and looks like it can actually hold tools without collapsing on itself.:D
jim1987
Young buck, what's the deminsions of that box. Also that 350 looks awfully familiar, like maybe I seen it on a Facebook page today. Lol. Hope one of us wins.
young_buck
Alberta, Canada
It is 56" wide x 18" deep x 34.5" tall, and if you have been on the sloppy mechanics public page then you have probably seen it posted a few times
young_buck
Alberta, Canada
Yeah it is, that's why I went for it. The slides could be a little better but it's a heavy box and it's got the full length drawer I've been wanting for a while
AndrewV
Fl
My organizational ocd, is going nuts after seeing some of the boxes today.
But looks good Young. Great to have someone starting in the field on here. Lots of old farts to help, and us that have been at it for a while ;)
619DioFan
San Diego , Ca.
Pliers and pullers
Screwdrivers
hammers and prybars
I think something is wrong with your truck. it is full of " white stuff " what is that ? we don't get that here in the 619:dunno: you should turn that 350 into a 383 stroker JMO. BTW - nice tool box !
young_buck
Alberta, Canada
Haha here in Canada we call that white stuff "snow", I have been knocking the idea of stroking the 350 around quite a bit actually, and it's already been bored .030 over so it's already a prime candidate. I got the safety wire pliers for under $10 at a yard sale, I figured I might as well get them for that price even if they never get used
JustinsGr8
Fort Washington, Maryland
Here is my "new used" KRL777 :willy_nil
I have been trying to find one the day after I sold mine...:dunno:
I will post pics of the other boxes soon..
