Let's see your vintage drill bit indices
Firebrick43
West central Indiana
Interesting.
Oh, you noticed the drunken sailor numbers, eh? :) Concur, though. I was intrigued with the choice of material and, while adopting the basic elements of the classic rotary index, not the same mechanism.
Here are some photos of my antique Morse, which countersunk the spring in the bottom with a split-screw.
I was wondering how it selected the two sizes. Thank you for taking it apart as it shows that clearly!
KnurledNut
n/a
Did it come with the transfer punches?
No, I just had them and they won't fit in a regular folding index. I wanted to see how they looked in this type stand and then decided it was a good photo op for the GJ masses. :rocker:The 17/32 punch is now homeless though.
Patrickm82
Massachusetts
Grabbed these 2 drill index’s at yard sales. First is a Cleveland twist no. 54 that I just filled with some Cleveland maintenance length bits. Next was a National twist drill number set at one stop then a Vermont America index that’s pretty crusty but the bits seem unused except for 2-3 at another stop. Missing the #16. Filled the national with the bits and chucked the crusty case.
Patrickm82
Massachusetts
Another yard sale find. New Process twist drill, index. It’s missing the “handle” but should be easy enough to whip something up. I’m thinking a plane knob I have kicking around from a trashed plane and a big taper pin🤷🏻‍♂️ The company was about 30 minutes south of me.
^ Moving files, I came across these in my "New Process" folder:
  • 1895 Hardware Dealer Keuffel & Esser New Process Twist Drill Prentiss vise Richardson ad pp 738.jpg
  • 1897 Hardware Dealers Magazine Howard Johnston New Process Prentiss vise ad pp 786.jpg
Dave455
Sussex, England
Here are a trio of unemployed stands for number drills.
Dormer Enox and an unnamed modification of the Dormer molding.
Those were msnufactured by Frys (London) Ltd.
They turn up with a variety of names on them.
Most are very heavily constructed, but they are also made in a light alloy. Difficult to tell if you are buying online, so buyer beware…
”Enox” was Fry’s own brand.
Several of the auger bits in the box are unmarked but mostly in the style of Russell Jennings as are the bits in the roll. 84D5EB2D-F6CE-45B8-9BF5-C293C33C2EDD.jpeg
I appreciate all the research.
I found a larger version of the auger bit holder on the left on Friday at an estate sale. I’ve cleaned it up and glued up come cracks. The bits went through the evaporust treatment. IMG_6412.jpegIMG_6462.jpegIMG_6463.jpegIMG_6457.jpegIMG_6488.jpeg
The bulk of the bits are marked L.S.&T. Co. I don’t have any of that brand in my spares
I keep staring at the illegible patent dates stamped on the two boxes and comparing to the dates his patents were granted. It could be the patent that was granted May 30, 1893. There are several choices and I am definitely not certain IMG_9779.png
not a clue.
Bartlett / George H. Bartlett, Bethlehem, PA / box for auger bits / patent 498455 May 30 1893 George H. Bartlett / https://datamp.org/patents/displayPatent.php?number=498455&typeCode=0 /
datamp.org page for that patent shows manufacturer as "unknown", so that doesn't provide any leads to "L.S. & T. Co."
The box was a generic, used by a couple of brands. I have a list of brace box patents see part of it here
I looked through plenty of auger bits trying to find a match with no luck. I found some Lakeside and Keen Kutter ones though. IMG_6495.jpegIMG_6499.jpegIMG_6497.jpeg
"Somethong" Steel and tool Co...
"L"
Lakeside or Lake Side?
Lakeside Steel & Tool seems to only exist in the mind of the AI reference material (translation: hallucinating or lying, depending on whether you are a developer or a user). I found nothing in Google Books
OccupantRJ
Eastern North Carolina
My shop was flooded 5 feet deep in a previous location 26 years ago. This set of excess drills cabinets was mounted on the wall behind my lathe at the 4’-8” level, so a couple of lower rows of drawers took on water. After refreshing a few Huot indexes of drills for use and cleaning the lower rows of drills before rusting, the rest stayed as they were and got wrapped with stretch wrap for shop relocation. Fast forward 10 years.
In 2010 I finally got my present home shop up and going, so since then has been setting up and using the shop, refurbishing and refreshing the flooded machinery and tools, and enjoying retirement. A new refurbishment hobby arose from all that. Since I had drills to use, the extra drills in the cabinet had not been a priority. I recently decided to tackle that nine armed spider monkey, so laid all the drills out on a large table, washed all the plastic drawers with Awesome cleaner and Dawn Powerwash, and got at it.
The cabinets were mounted on the wall above my present lathe, all drills measured and sorted, and labels applied. This relatively small project was the last of the flood effects left visible in my shop, and it was a really mentally refreshing closure to get that done. I hand wrote the labels to match what I had done in 1999, so it all looks exactly like it did then. The beauty of this system is that when at the lathe you can reach over and select a drill without moving away and leave the drawer slightly open as an indicator until the drill goes back in the proper drawer. The several sets of Huot indexers are kept on the tooling cabinet next to the Bridgeport mill.
For some reason this homemade index appealed to me so I brought it home yesterday. I can’t decide whether to try to modify the holes so bits actually fit in them or just leave it as is. I could probably use the lowest row with number bits. It needs to have some bits weighing it down or it falls over on its’s back. IMG_7015.jpegIMG_7016.jpegIMG_7035.jpeg
Anything is possible. Some of the holes have hand written markings of drill bit sizes. I’ll check those size bits to make sure they fit those holes. It’s a bit of a mystery why it’s so illogical.
