Lets see your vintage shop work lights
paulm12
NW Chicago 'burbs
I recently picked up my 2nd Dazor, this one a model 2134. Is not in nearly as good of shape as my previous find (is in this thread). The power cord is severely cracked, and there is some rust. I was wondering if anyone here has tried to replace the florescent lighting with LEDs? I have to rewire this lamp anyways, at least up to the lamp base, and some of the internal wiring is questionable. I may take it apart to paint, and was wondering if updating the lighting type may be a better plan?
Evergreentree
Montgomery County PA
Don't know if anyone's watching this thread anymore, but some cool lamps you all have. I just picked up my first old shop light today. A Fostoria sewing table work light. All original, except for a plug and a bulb I replaced. Had to have it, way cool. I was tired of looking at newer stuff! Not mounted yet..
Pupuhd
New Jersey
Don't know if you ever got your answer however now a days they make LED lights in the same format as the old florescent tubes. They just plug right into the same sockets and have the same pins on ends. No need to rewire anything for LEDs unless like yourself the wiring needs replacing. Good luck-David
rickhigginshtbr
Lower Bucks, PA
Forgot about this thread! Picked up a third Dazor the other day... actually, the gf's son picked it out at the thrift store saying "this looks cool!". Doesn't it kid? ;)
rmalkow2
Brighton, MI
I forgot about this thread too. I picked up this lamp about a week or so ago. It will be a perfect wall mount over my garage workbench. The "Swivelier". It has a cool ball swivel joint built in to direct the lamp coverage. Came already re-wired and with a built in mounting plate.
paulm12
NW Chicago 'burbs
thanks David. I have the light apart now, awaiting warmer weather to start painting. I will try to use the existing internal wiring first. If there are issues I may try the LED solution you mention.
Paul
paulm12
NW Chicago 'burbs
good for you. I have been on the outlook for these now for about a year (thanks to this thread). Only 2 Dazor so far, plus one lower quality unit as well. Always on the outlook for more.
paulm12
NW Chicago 'burbs
great looking light.
paulm12
NW Chicago 'burbs
cool light. What bulb is in it? How bright?
don long
southern california
Here is my vintage work light
rmalkow2
Brighton, MI
It has a 100w incandescent in it now that came with the light. The plug on it was smashed so I have yet to replace the plug. Should throw enough light as a task light not too high over the bench.
Jazz1
Thunder Bay On.
I could not pass on this old light for my welding cart. $6.00 at Sally Ann. Made by Art Specialty Co. Chicago
tym
i'm always looking for vintage industrial lamps, but this is the only one i have.
My dad has a nearly identical lamp, in brown, bought new in the 1950s. It sits in my folks' downstairs room and gets used nearly every day.
Gidge
New England
This is a great thread, I have a pretty decent collection of old lighting fixtures --here is one :
Gidge
New England
Gidge, I've been eyeing up that one at a shop near me for a while now... they want $65 for it, and in rough shape... ugh. It is cool though!
If you clean it up, adjust and tighten (or modify) the fixtures then paint the lamp some vibrant bright color you could make triple the asking price on Etsy or Ebay --people like retro stuff.
For myself, I like the original look, even if it is a little beat up.
cleason
austin texas
ive got asome pictures of mine. the porcelin reflectors are from the 20s.the school house fixtures are from the 40s.the snap-on lighted display not sure.the strip light is from the 60s, has been retrofited with t-8. all of these came from schools. i have the globes for the school house fixtures,there packed up so not to break them.the top of the shelf is more reflectors and a ww1 stonco building light. the flower bucket is home made for my daughter, shes an interior designer.
2oolhound
BC Canada
I picked up a cool old trouble light a few months back, $2 at the flea market. It has a heavy glass cover over the bulb.
The po had a thin tin sheet behind one side to reflect all the light forward and probably to prevent being blinded as you work behind it. The other side is polished close to chrome so I kept it there.
Works Great!
2oolhound
BC Canada
I should probably start one of those "how I waste my time threads" on this but it fits here pretty good too.
I picked up this flourescent lamp at a garage sale thinking it was a dezor like I've seen on this thread. The seller was a young machinist who I think decided as cool as it was it just wasn’t worth his time to look into fixing it. Although the lamps lit up, all the joints were really floppy and it definitely needed work to make it functional.
…and oh, did I mention the brushed on orange paint job?
The ballast looks a little scary. Wonder how many PCB’s I’ve picked up so far from this thing.
Taking the reflector out was interesting. Everything on this lamp was put together with no consideration about ever taking it apart again. Some flat puddy knives worked to pry out the reflector.
The tube sockets were screwed to the reflector so once removed the sockets were unmounted.
I have it all stripped down to individual pieces.
The base swivel was really floppy.
Looking inside you can see the inner stem is just flattened over the inside of the base tube, no nut to tighten down. I pounded it flatter with a big brass drift which tightened it up pretty good.
The 1st boom arm was really loose in the elbow. After opening it up I could see why. The end of the tube doesn’t extend far enough to catch the second support casting. The little bump on the end is what hits the raised bridge between the other 2 raised castings and prevents the lamp from turning completely around and twisting the wiring.
I added a small piece of the same size to the shaft by mig welding. The aluminum rod and brass shim were just to keep it aligned.
I built up the little bump stop into a full size lump to stop the tube from turning 360’. I also built up and flared the end out with more weld so the tube really locks into place now.
The pin in the top spigot has pressure from a spring washer to keep it tight. The end of the pin hits the tab on the lamp house to prevent it from turning 360’ and tangling the wiring.
With most of the fettling done it’s time to change the paint colour. I soaked it in acetone which lifted the paint in 20 minutes.
The paint lifted off cleanly.
I have since this, painted everything kind of a deep wine colour (it's what I had on hand) and it's all awaiting re-assembly.
I'm planning on just sticking it all back together with the same ballast, wiring and bulbs unless anyone has some better suggestions.
So here it is with some new paint. Only one bulb is lighting now so maybe the ballast is finally going.
The joints were buffed up instead of paint and they turned out nice.
carbon
Is that a fluorescent? If so, didn't know that tech was that old.
ichabod
minnesota
Very cool light fixture. Did you restore it or acquire in that nice condition?
it was in a friends basement, it was in poor shape, the steel parts were rusty, aluminum was bent up and glass was broken. I clean and painted and converted to t8 lamps and ballast. the original end caps were missing, so I bought those wood deals and painted to match.
here is an original advertisement for the fixture.
