Lets see your workbench
astrohip
Brenham TX
I hung closet maid across 30ft wall, I am happy with it.
To answer questions, yes cut to length with bolt cutter, then rubber cap on end.
also can vary the depth by changing supports so recesses can be mad flush with other shelves. As to putting smaller items Rubbermaid sells shelf liner made to fit the shelves.
I used the fastrak system, making it easy to modify. Then if you can buy a closet kit to start and add/subtract parts it is cheaper.
Lastly I wait till Menards has 11% rebate as Rubbermaid/Newell/ClosetMaid all think a lot of their stuff.
Thanks, good info. Is the fastrak system different than what I see on their web site?
John in OH
SE Ohio & Eastern Virginia
Can you please elaborate on this portion of your post, "... also can vary the depth by changing supports so recesses can be mad flush with other shelves."
I'm not clear on how you can vary the shelf depth.
bugnut
Central Ohio
Astrohip & John some answers for you.
an image of the shelves in my building are in this post
https://www.garagejournal.com/forum/...59#post8615859
The system I used is from Menards it is ClosetMaid® ShelfTrack White Wire Closet Hang Track (sorry I called it fasttrack)
It uses the metal shelftrack at the top/highest point and allows the uprights to be spaced to meet your needs. I located them on the studs so I could load with more weight. The uprights have screw holes in them so the can be anchored with more than drywall fasteners.
John the shelves are available for various depths 6, 9, 12, 16 & 20 are standards and they all match if you select and stick with a single pattern. I have installed the system with spacers behind the shelftrack and uprights so that the fronts were all face matched.
While looking for information found this pdf it lists most of the information.
https://design.closetmaid.com/en-us/Documents/Wire Shelving Specifications rev_6_12_English_HQ.pdf
astrohip
Brenham TX
Getting ready to install some of this, quick question:
What's the purpose of the "Hang Track"? If you have vertical standards, what does the horizontal hang track do?
Thanks.
mv213
Dallas, OR (the OTHER "Big D")
Thanks.
It allows you to place the uprights wherever you want instead of only on a stud. Also makes mounting the uprights super fast. I usually don’t use the hang track, instead I screw the uprights directly to studs. However, it takes longer to get the tops level so your shelf slots line up, if you don’t use the track.
astrohip
Brenham TX
Thanks, GREAT info!
Craig Balzer
Colorado Springs
Just finished the last polyurethane coat on the bowling alley benches.
Put the new ICON tool chest between them
The old library card catalogue in the corner
and the old blueprint cabinet below the window
Rkcubed
Missouri
I’ve updated my wall storage. Made several hammer racks out of scrap metal and several out of rebar.
Made custom wall hooks as well.
bugnut
Central Ohio
Astro, mv213 is spot on.
I was able to hang the vertical where I wanted them without a stud. Then I used hollow wall anchors with a 100lb capacity for the vertical attachment. Came out nice and tidy. If you install the hangtrack up high enough you may be able to attach it to the top plate with a good quality fasteners.
drivesitfar
nice looking shop. more close ups of your bowling alley top would be great if you have time to post a few more.
also if you'd like to post up more pics of your wood library cabinet on the wood cabinet thread in vintage tools please do and here's the link: https://www.garagejournal.com/forum/showthread.php?t=305831
also I can't say i've ever seen anybody paint their big flat file cabinets red. if you'd like to mention how you did it and how long it took you on the metal cabinet thread in vintage tools please do.
nice roomy shop BTW!!
Black300zx
Elkton, Md
Did you intentionally put the Snap-On banner above the ICON tool chest :beer:
Craig Balzer
Colorado Springs
more close ups of your bowling alley top would be great i.
also i more pics of your wood library cabinet
also I can't say I've ever seen anybody paint their big flat file cabinets red. if you'd like to mention how you did it.
Done, done, and done.
The shop is 2300 sq ft: high bay is 48' x36' (with 14' ceiling) attached with a walk through to as 24'x24' storage room with 10' ceiling. Do you believe that I think it's too small -- -- and I just got started restoring my XKE.
Thanx for stopping in --
LeonardY
Southern California
Here's mine. I laminated two layers of shop ply with West Systems epoxy to build the carcass. I had a buddy weld up the brackets for the casters. It's a beast. It rolls well once the wheels are going in the right direction. I just chock the wheels when I don't want it to move.
Youngandfree
VA
My basement work area.
DaveT
St. Louis area
That’s a fantastic bench Leonard. Tons of storage space. Is that a Emmert pattern vise?
LeonardY
Southern California
Thanks.
No, it's a knock off. It works OK. I thought I would use it more but now I'm actually thinking about removing it and putting a regular vice there. I have a really neat old vice from my Godfather's farm.
DaveT
St. Louis area
Thanks.
Oh interesting. I have not seen a knock off one. My next question was going to be how you liked the Emmert and if it was as good as all the hype. They sell for crazy money.
LeonardY
Southern California
This is it. I think I paid $300 for mine.
It's come in handy on a number of projects. It's great to hold odd shapes. But overall I would be happy with a regular woodworking vise like the one on the end of the bench. That one is a quick release. which is very handy.
I have an Emmert on my bench at work. It feels tighter and solid. We don't do much pattern making or wood carving any more and no one else wants it at work. It's kind of sad.
If you do furniture with carving or odd shapes a lot. It's definitely worth it.
As far as the hype, to quote Spock "After a time, you may find that having is not so pleasing a thing after all as wanting. It is not logical, but it is often true."
4lug39
Bastrop,Texas
I got a couple from one of the agencies at work that was upgrading their benches.
I've only got one together so far but also only have half my garage cleaned. I bolted the bins down and just used a large C clamp on the vice for now. 2096.JPG
bulletpruf
San Antonio
Moved to Virginia for work for a few years, so I had to set up garage #2 on a bit of a budget. A Craigslist bench, along with a CL benchtop drill press and repurposing some existing pegboard, and I'm in business.
steaks&anvils
Colorado
Nice. Nice bench!
Safety moment, make sure your drapes don't get pulled into the drill press... And no chainsaw testing in the rec room!
Adk Mike
upstate NY
Here’s a bench I just finished for my son in law. The file cabinet I bolted in as a low budget tool storage.
made from 2’ square stock. Has adjustable pads on the legs. The vise is removable with a pin on an old trailer hitch
VTX1800
Near Council Bluffs Iowa
my wife does metal sculpture, I do cars, as her skill sets improved so did the necessity for better equipment. I built this four foot by six foot fab table using 3/8 steel for the top, the rest was sourced from our "inventory":) I can move it around by jacking it up on one end with a tongue hitch on one end and castors on the other, electrical outlets on all four corners, two inch receivers to hold other tools (benders, vise etc) on three sides, a "rack" to hold grinders and one leg is adjustable because our floor is good but not perfectly level. My wife suggested adding a perforated metal shelf to store tooling...plus the dust just filters through. We've used it almost six years and the only change was to change one of the four outlets from a "two" plug to a "four" plug:) I don't think we only used the mobility feature when we moved it into place.
astrohip
Brenham TX
Nice job!
Although slightly off-topic, I would love to see some pics of your wife's work. I find metal sculpture fascinating!
