Lets see your workbench
Hornung418
Skookum brackets from Eastwood Garage for my first ever bench build! The previous bench was a door supported by two 2x4s nailed to the block wall and a PVC pipe leg epoxyed to the unsupported corner...e5c992094877b008297055456f37b436.jpgc8de5f8b8f0c092f87f6dc7e6ecbfdef.jpgaff076c39891b46f04b622da50414eda.jpgbcbcc785f1cf7b887dd22a9bad1952c5.jpgd4c3b0d7e057393a88da02a66c18cd53.jpg24c772206fa2f7e8db44e6e5889bebd9.jpg
Sent from my Pixel XL using Tapatalk
scarrylarry
West Coast of Canada
Wow !Those look like skookum brackets ,how much were they ?
scarrylarry
mackie232005
A make **** work table are at The Mayowood Stone Barn, another one of our properties
Moving tools around from property to property
rjprice
tx
Still setting up my shop. Bought this Equipto workbench a long time ago. Repainted the top and now the base looks ratty.
Welderguy24
Alexandria, MN
Bought a house last September with a 26x24 attached garage, now that spring is here it's time to get started on a workbench. So far I have this design, 10' wide, 30" deep, and roughly 42" tall. Constructed with 4x4 legs, 2x4 and 2x6 framing, 3/4 plywood top, and 1/2 plywood shelf.
Thoughts, Ideas?
astrohip
Brenham TX
Thoughts, Ideas?
That's similar in style & construction to one I built last summer. I am *very* happy with it--strong as an ox, looks good, works great. I think you will be happy with it.
Mine is 12' wide, about 30" deep, 30" tall. All 2x6. No back shelf, as it backs up to a wall, so I used pegboard.
Welderguy24
Alexandria, MN
Got it all done, used the extra 3/4 plywood from the top to make the backsplash and the upper shelf attached to wall. Turned out absolutely perfect.
QwikKotaTx
Seabrook, TX
Thoughts, Ideas?
I can't tell from the design but make the top overhang the frame for clamping. Mine is a layer of 3/4 ply with a 3/4 later of MDF on top. I have beat the hell out of things in my vise and no issues. I screwed the MDF down from below so no screws visible on top. Edge is routed over round and flush with ply layer.
ByJustSomeGuy
SC
So who know's anything about this beast. Was told it was from England...no way to confirm. No names, patents, numbers, etc...
5 feet 8 inches long.
12 inches wide.
3 inches tall
4 hardy holes that are different sizes from each other. Smallest just under 1 1/2 inches, largest around 2 inches.
Weight = heavy...I'm guessing more than 250 lbs.
Bman75
Finished mine last week. Thanks for all the previous workbench posts on GJ because that's where most of the ideas came from!20180429_203457.jpeg20180429_203508.jpg20180429_203522.jpg20180429_203535.jpg20180417_182840.jpeg
Sent from my SM-N950U using Tapatalk
Bman75
Thanks! Now I need a slightly taller stool though. That one isnt adjustable, and it doesn't have wheels. I want to be able to slide over and get to the tool box without having to get up lol
PurpleZj
Louisburg, Ks
That’s not lazy, it’s energy efficient lol
mrramsey
North East Ohio
Still a work in progress. Have to put the finished work surface on there as well as finish building the doors and drawer fronts.
coljar
Belpre, Ohio
[/url][/IMG]
I was concerned about it being 37" high but not after I've used it a couple of months.. The 3/8" x 2 1/2" angle iron around the edge has been very handy for clamping.
lowcheve
my bench build work on making top now
drivesitfar
LowCheve: nice looking bench and I really like that you built it with bolts in case you might want to change it up later.
ALL: speaking of bolts and nails do any of you use NAILS TO BUILD STUFF NOW? I'm really a fan of tork screws and the 8 prong spider bit and screws is really becoming a favorite for putting some large pieces of lumber together.
BikerDad
Utah
So, I realized I have fallen woefully behind in providing workbench pics. I have 3 workbenches, although many won't count the workmutt, so we can ignore that one.
This is my old workbench, shown previously. It has been widened by 12", had an 1/8" thick steel plate (or is 1/8" still in the "sheet" category??) added to the back, all of the stretchers have been raised, and it's now has a lift kit. There is still a Record QR woodworking vise on it, on what is now the back side, as I use this for metal work.
BikerDad
Utah
Here is the new workbench, a Split Top Roubo. It is @9' long, 28" wide. The top is 4" thick hard maple, the base is soft maple. Accent is provided by purpleheart. It has a Benchcrafted Crisscross Leg Vise and Benchcrafted Wagon Vise. The first two pics were when it was almost complete. Since then, a cabinet that sits under the back slab has been added for tool storage, the center gap has two filler pieces that can be removed, and a sliding deadman has been added. The third pic is it completed, in use sometime in the last couple of years.
mrramsey
North East Ohio
Very nice!
droach77
Independence, MN
Just finished a mobile work bench. 6 1/2 foot bowling alley top gives me a good work surface for restoring my over 100 vintage post drills and allows me to display 3 of my patternmaker vises -- an Oliver, Emmert and a Yost.
rt9
Which floor tiles are those, Swisstrax?
Sent from my SM-N920P using Tapatalk
drivesitfar
Droach: love the bench and wondering if you had a build thread or more pictures of it during the process of making it? it's about perfect for me and if I could figure out how to put my table saw in it all the better cause i'm lacking extra floor space.
Ron: nice looking shop and benches? are we ever really ORGANIZED as good as we could be? it looks like you've got it set up to work nicely and thanks for posting the picture.
droach77
Independence, MN
Unfortunately I don’t have progress pics. I had my local welding shop weld a 3 1/2 by 6’ frame out of angle, added a set of 600 lb each rubber cas casters, a four drawer tool box (without the wheels) and built the rest of from there.
Moose02
New Jersey Shore
work in process
