Lets see your workbench
Ryan_340
My current workbench project in my work shop that is still under construction.
Radio Joe
Laurens, SC
Sorry to be so late with the response. Seems that some days I get notifications and some days not.
I used screw on tee nuts under the top. They are super strong and easy to install. No way the regular drive in stamped tee nuts would survive very long in this application.
I had to make up the hand screws from hand knobs and all thread since the top is 2 1/4" thick plus the 3/4" bases.
I countersunk the holes in the top for some stainless fasteners to plug the holes when not in use.
THIS!!! Been hunting this thread for ideas to add to my bench and this solves an issue for me! Thanks!
colt zantop
michigan
We just built this one. If your in Michigan, we can build one for you!
Ryan_340
Just about finished with my work bench project.
Chris_the_wrench
Chinook Pass
That looks better than alot of kitchens. I'm curious how people who mount their grinding wheels to their nice work benches keep the area clean? My grinding wheel area is the mess pit of the shop with constant metal dust and sparks thrown around the space.
-Chris
Loose Ctrl
Upstate SC
-Chris
On metal benches, I mount them directly to it. On wood benches, I make a 3/4 inch plywood plate, an inch larger than the grinder base, to go under it to protect the bench top. Sometimes I will file the bench grinder's base round along the edges. It keeps it from cutting through the wood as it vibrates.
gearhead1
NC
Nice work!! I see the 2x4 construction, but what is the face trim of the cupboards made from? Also what did you make the cupboard doors themselves out of. I’m considering doing something like this.
clcartwr
Rogersville, AL
Here are mine. Main work bench, Assembly table/outfeed, and miter station. The assembly table probably sees the most use and I'm still working on my main work area.....trying to get a feel for the space to get a good layout.20180808_195034.jpeg20180808_195058.jpeg20171110_012925.jpeg20171109_180712.jpeg
Sent from my SM-G950U using The Garage Journal mobile app
maydaymike
Here are the ones I built a few weeks ago. I still have to cut the bottom shelves on the 8' benches (I built two of them), and cut Masonite for the tops. ee4654b8bf0f84ae8beb41fcfc297457.jpg48c6cec7e1b248fbbea51fed75e165b8.jpg
Sent from my SAMSUNG-SM-G891A using Tapatalk
aabirdman
So Cal
if I could find it I would post a picture of it. But there's so much stuff(****) on top of it you can't see it.
rpcraft
Waco
Yeah I got a good deal on a load of the plywood so every thing in the shop is made using it. Finish is a couple of coats of wipe on poly and wax. Actually holds up better than expected....
I used that on my rolling bench and then I decided to start doing some plasma work and that does not mix well with a wood bench. I'm thinking I am going to get a nice sheet of Aluminum to put down on top just so slag and stuff doesn't start burning a hole in the top around where my vice is. I'm going to add a router plate and drop down table saw as well so maybe I'll just put the aluminum on the whole top and have a tab that hangs down for a ground clamp and that way my vice will be grounded to it for welding.. Hmmmmm Will aluminum work ok that way or would steel be better? Not trying to put a 1000 pound top layer on it?
andy013
Pittsburgh
Steel would hold up better. Make a thin sheet and use the wood as the core like all the stainless tops are on tool boxes. All depends on how heavy of items are to figure out how thick you want the metal top. Not sure how the aluminum would hold up with the plasma cutting and welding; good conductor though. :)
maydaymike
Making progress! 5d12f06622db2f3d0abb4acb2da62215.jpgabdd77e0a82af793cacda1218c238096.jpg1d0601653a4f80af1ef37db27a7dc20e.jpg
lkempf
Indiana
My corner workbench. I have since added a shelf above it with lights mounted on it.
Hpozzuoli
Rhode Island
Thanks guys. I just redid everything so I have no clutter on the ground. So far so good. I got rid of a lot of stuff..sandblasting cabinet, big compressor, lots of extra unused stuff. I kinda like the clean look now.
The ceiling lift has been great. I keep my tile stuff on it. Probably over the weight limit of 200lbs.
Ambrose Wolfinger
Arlington, TX
Question from a first time work bench builder. In looking over various designs, I notice many are held together with wood screws. Would it be better to use larger lag screws, or even hex bolts with nuts? I haven't yet settled on an exact design, but plan on using 4x4's for the legs, 2x4's for the supports/cross pieces. and either ply wood or 2x6's for the top.
iagsxr
Vinton, Iowa
Deck screws, then I've ran carriage bolts through the 4" x 4" legs and crossmembers to tie it all together.
Plywood top will be way nicer than 2 x 6s unless you're going to then top it with steel or something.
mslim
Fayetteville, AR
Just a one car space but it works for me. Chicken house fan is a must in the Arkansas climate.
zmotorsports
Northern Utah
Thanks Mike / Jim - after use a quick hit of wd40 and wipe and good to go.
The WD40 would work well but if you get a chance try some Sheila Shine. It is made for stainless steel restaurant equipment and it works terrific on SS. I even use it on my hot rolled sheet on my workbenches and it works great. Seems to last quite a while also.
Ambrose Wolfinger
Arlington, TX
[emoji106] you're probably right about the plywood versus 2x6. And I think I'll probably do what you suggest by putting it together with deck screws and then bolting it together for extra security.
JimVonBaden
Northern Virginia
Nice BMW R90S you have there! Best configuration!
I like your gear rack as well!:thumbup:
Loose Ctrl
Upstate SC
This is overkill unless you're planning to put extremely heavy items on your table. Notch the 4x4 for the long runs of 2x's and use carriage bolts with a flat washer and lock washer on the back side. Deck or constructions screws are OK for just working on light projects like a small aluminum 5HP to 10HP lawn mower engine. I wouldn't go plopping a big ole V8 up there unless the 2x were notched and bolted. Just my two pence.
