So there I was.... In a confluence of chores, wants and material.
I had just bought this Harbor Freight Lift :
And then wanted to finish getting my bench installed. To back up a little; a friend had been remodeling his kitchen and gave me his cabinets to use as a base for my bench. A lucky strike at IKEA scored me two solid oak counter tops. I had to cut the backs of the cabinets to fit over the blocks of the stem wall but that was all to be done done at this point.
Once I finally go the cabinets set in place, I could finally move on to getting my non-pegboard pegboard up. I wanted to use a sheet of plywood instead of pegboard.
All of a sudden the light bulb goes off and I try this....
Yup... That sheet that looks to be birch plywood is the top from the Harbor Freight lift crate.
I found the studs and put it up and here was the first cut at tool organization...
Then as I'm standing there thinking about the pegboard shelf brackets I have and the fact that I'd like a place for my soldering stuff and other small things that would clutter up the bench....
Yup.... That's the end panel of the Harbor Freight lift crate. It even has an inset panel on the top that keeps small items from rolling off.
For instance I had to disassemble that fan that was on the bench to clean it and the shelf nicely held all the screws
Here's the close to finished bench with vice and power strip installed.
Now I just have to final organize and I've got my nice working spot.
Life is good.
TG
