AntonLargiader
Has anyone used them? I haven't seen them mentioned here at all but they are certainly out there in the stores. Home Depot sells them but there is also a lot of stuff on eBay.
Aside from the styling, the big features seem to be the full plug-on design, availability of hydraulic/magnetic trip, and the availability of smart breakers (which can be controlled and monitored via an app).
The cost isn't that different than the others.
1-pole DF breaker - $40 and up
1-pole standard breaker - $7 and up
2-pole standard breaker - $18 and up
GFCI 2-pole - $76
And the load center costs are maybe a bit higher but nothing major.
Hydraulic trip is apparently a cold-weather thing. Eaton makes HT breakers but I'm not sure they are in the US.
Smart breakers are obviously going to be a lot more expensive, but that's only if you want them.
Full plug-on sounds cool. Seems to be an installation time saver, but I can see modifying circuits being a bit easier also. Not a big deal; my breaker-moving time has very little value to economize.
So, some different features at a similar cost to the other products that are out there. I don't know the construction details like bus material and plating.
https://www.leviton.com/en/products/residential/load-centers
Any experience?
GFCI 2-pole - $76
Any experience?
