Leviton Timer programmable Q
American Locomotive
Rhode Island
Generally if something says for "incandescent only" like that, it means it may have issues functioning with LED or CFL lights. Usually what happens is when it's "off", you may get a sporadic flicker of light every so often, and erratic behavior when its switched on, like flashing and intense flickering. The "triac" based circuits they use often have difficulty "firing" with low, or capacitive/inductive loads as LED and CFL lights often are. They require careful designing of the circuit to work properly.
Or it might just work fine. It's hard to know for sure.
cybrdyke
USA
• This device is not intended for use on electronic ballasts.
this warning is right below where it says "for incandescent only".
LED has an electronic driver which is essentially the same as an electronic ballast.
CD
6PTsocket
Good explanation. I was trying to figure how to explain it, but you did it better.
