Lift motor wiring
kcautorepair
Springfield, MO
Hey everyone, first post here. I'm in the process of installing a gilbarco/manitowoc gff-70 lift. I'm stumped with the wiring. From my understanding, the plug is a 110v plug, but the motor is a 220v. Anyone know what I need to do to get this wired up? I'm going to be running a dedicated circuit for the lift, I just don't want to buy the wrong wire. Attached are pictures of the plug that is already on the lift, and the info plate off the motor.
20241206_111616-jpg.2233329
JohnX14
Boston 'burbs
Notice the non-molded plug on the lift. I'm assuming it is used and previous owner used whatever he had in the shop to install or repair it.
micromind
Fernley, Nevada, about 30 miles east of Reno.
20 amp 2 pole breaker in the panel, #12 wire (2, any color except gray, white or green plus the ground, green only), a 20 amp 250 volt outlet and a new 20 amp 250 volt plug to replace the existing one.
If you're using a cable of some sort and it has black, white and green, you can use the white as a hot (one side of the breaker) but it must be identified as a hot. Red tape will do, coloring it with a sharpie works too.
K
kcautorepair
Springfield, MO
To clarify, the plug on the lift was there when I purchased the lift. I want to make sure everything is correct before I attempt to plug it in. I wasn't aware that you could run a 220 v motor on 110v power. I have a 220 outlet not far from where the lift is that I can use for the lift, I just don't know 220v circuitry.
You cant.
The motor would need to be dual voltage rated, 115v/230v. Or, in your motors case, triple voltage rated (115v, 208-230v).
pattenp
Virginia - USA
The original owner had to have it wired as 240v. They just used the wrong outlet and plug and wired as 240v. The neutral of the 5-20 was used as a hot. 240v is two hots whereas 120v is one hot and one neutral so the 5-20 can actually be wired as 240v.
