liftmaster 3900 question
jack stand
Lakes Region Maine
Do any of you guy's know how I can jump the wires to NOT install those stupid "eyes" and have the door work properly. I'm adding another opener and with my other 2 I just have the eyes pointing at each other up at the ceiling level. I'd like to not do this with the new unit and will do the some with the other 2. At the time of installation with the first 2, I had a fit just setting the limits and such that I figured that the eyes should be set up as intended, just never got around to playing with them again.
By the way, this is how I found this forum, (researching the 3900) and I am glad I did!
Also, the antenna is a skimpy 6" wire that does not perform well with (I am guessing) with the steel siding on the exterior walls. Is there a simple, non electronics skills fix to this issue? Thanks.
AndyL
Vancouver
Can't bypass photo eyes...
And if you have range issues - might be worth testing an 888lm and the security+2.0 remotes , they seem to perform a bit better than the previous version
