Liftmaster 8500?
Nexussian
Alaska
Door size is not a problem
Door setup is.
X2
If it won't lift your door, then there is some issue with the installation.
Either too weak of a spring setup, or not enough preload (having said that you will probably have counterweights :lol: but you get the idea).
pattenp
Virginia - USA
20 X 11 exceeds the specs for the Liftmaster 8500. Specs say up to 18' wide or up to 14' high at a max of 180 sqft.
