LiftMaster 8500W vs Chamberlain RJO70
tech101
SF
HI,
I am new to the forum, I wanted the community expert advice or want to know experience which one is a better for garage door opener I kinda like two. Trying to decide which one to go with..
chamberlain.com/chamberlain-next-gen-wi-fi-garage-door-opener/p/RJO70
Or
liftmaster.com/liftmaster-8500w-wall-mount-opener/p/8500W
:thumbup:
T
tech101
SF
Ah, Good to know thank you so much LS6 Tommy. So Liftmaster should be a better opener overall. ?
LS6 Tommy
Northern NJ
It's really hard to say for the models you're looking at. They look very similar, almost identical, and I don't have a lot of experience with residential jackshaft style openers.
Tommy
vrinner
Placentia, CA
I can’t compare the two as I only have the lift master but the lift master does work perfect on my 12x14 foot doors.
driftpin
I have two Liftmasters like you wrote-of, and while I did replace the wall control units, because of issues, it was done under warranty, at no-cost. If you look on-here using the 'search' function, you'll see some issues discussed. I have never-experienced a garage door opening on its own, without my input. I do not have the internet controllability activated, but I do have the OH doors 'plumbed-into' the home alarm system.
I like the OH headroom that the jackshaft openers provide, here are some pics of using the space above the doors, and also how to provide lighting below the doors, so I have even lighting, OH doors open or closed.
The platform above the doors is for lightweight, bulky items like Christmas decorations and unused storage containers. The lighting is Costco 4 ft. LED luminaires, $20 apiece on-sale, for me, their lighting capacity is great. Up or down, the OH doors don't interfere with my lighting in the space below the OH doors. A sharp eye will notice the center luminaire is a florescent twin-bulb. I had it and used it, it was gifted to me and now it does good duty. I also have two of the Liftmaster wireless-controlled luminaires (380LM), one between the OH doors of the attached 2-car garage, and another at the door to the house. Open either the OH garage door, the exterior side door, or the door to the house, and the two wireless-controlled luminaires turn-on. My 380LM luminaires cannot use LED bulbs, the instructions say they cause wireless interference, and I was able to prove that, during my installation, I now use Edison-base screw-in florescent bulbs in the 380LM luminaires. The LED Costco luminaires, though they are a few feet from the Liftmaster 380LM luminaires, do-not interfere with the wireless reception of the 380LM units. A different frequency, or enough of a separation, I dunno, I don't need to investigate.
2level
Washington
I don't have any experience with the RJ070, but so far I've had to replace the wall control unit twice on my 2014 installed 8500. The worst part is that when the control units failed the garage door automatically opened. One time this happened in the middle of the night, and the other time nobody was home. We were lucky that nothing was stolen out of the garage.
TimNY1984
Buffalo, NY
I'm running across the same problem. I can pick up the Chamberlain from Lowe's and deal with them if there are any issues off the bat. The liftmaster I'd have to get from amazon for basically the same price. I don't really see what's the benefit of one over the other. I might just go for the chamberlain because I can get it right away and check it out.
Tim
MadeULook
Sac CA
I have ther RJ070 and like it a lot. The reason I chose this one is because I found conflicting product reviews stating the other unit is not truly wireless, for internet. I can confirm the RJ070 has wireless internet connectivity, without having to purchase anything else. The reviews I read about the Liftmaster states you will need to run a wire from the router to the unit, even though the product claims to be wifi enabled.
Plus, I got a really good deal on a "new-in-box" unit, off of Craigslist...
-Lee
TimNY1984
Buffalo, NY
Thanks for the info. I'm going to go with the Chamberlain RJ070, I don't have use of the liftmaster to compare it to, so i'm sure i'll be pleased with this purchase. I'll report back eventually on my usage and if any issues arise from it.
Tim
dw1
Ky
-Lee
I have 3- Liftmaster 8500's -2 on my barn doors and 1 on the house garage, all three are wireless and have internet connectivity, I do have the My Q Hub set up in my house and my barn. I can open all three doors from my phone app
SCATFEVER
New York
I have the RJ070s and love them.
I only installed them a couple months ago, but they are quite and I haven't had any issues yet. Easy install with everything you need in the box, it was great.
I have a 8'x9' door with long radius turns and angled runners to match the scissor trusses.
I haven't connected the WiFi controller yet, I just haven't cared to do it yet.
samendolaro
I have two of the older model Liftmasters (3800PLD). One of my Doors the Remote had stopped responding . I had upgraded to the MYQ control panels so I could then open them with the Phone app. My other door just started the opening and closing by itself.
Apparently the issue with the remote and the issue with opening/closing are both caused by the RECEIVER LOGIC BOARD failing ( $75 each) They lasted about 8 years with no issues
Aileron
outside
Had a door at our shop open up on its own in the middle of the night. Stayed open all night. Caught it on camera. Replaced the controllers but now cut power to the doors when no one is around. Don't trust them.
jmiller_2308
Shakopee, MN
I like liftmaster but availability at local retailers is certainly a plus for the chamberland. I succumbed to this convenience when I replaced a very old liftmaster (not jackshaft) with a chamberland version from Lowes. What I realized later was that the drive on the non-jackshaft chamberland was much cheaper than the liftmaster it replaced. I also have 3 other liftmasters, one jacksaft, 2 non-jackshaft, that were all on MyQ so I looked forward to having that on the new chamberland as well.
Unfortunately the other issue I have with the chamberland is that I use a panel on all my liftmasters that includes the ability to automatically close the doors after they have been open a certain amount of time. I tried to use the same panel on the chamberland and it wouldn't work. The liftmaster/chamberland website is beyond confusion when trying to locate parts that work together. In the end I had to use email to talk to the liftmaster folks that ultimately told me that the automatically closing panel feature is not available for my chamberland. That really *****.
So yes, liftmaster is the Cadillac compared to the chamberland chevy. Both will work but in my case the liftmaster had better build quality and more bells and whistles.
ch612T
PA
LiftMaster 8500W - local vendor I bought from sell lots of them. Works for me.
UmchChris
I just bought the LiftMaster 8500W….planning to install it this weekend to replace my old overhead opener. will report back…
ToddG
I had Liftmaster's on my old house and decided to try the Genie this time around. Both work fine and the Genie is a bit slower. I do like the Genie app where I can open the door from anywhere and check to see if it's open or closed.
hilld
Vancouver, WA & San Juan Island, WA
I have them both installed side by side. They appear to be identical, except the branding/coloring. All the bits and pieces were pretty much identical (lock, battery, control panel even the packaging). I can't say this with 100% certainty, but it is the same opener sold via different channels (Chamberlain in the retail channel vs. Liftmaster in the professional channel).
Not the best pic, but the LJO70 is on the left and the 8500W on the right door.
