Liftmaster install~
Denee007
Cypress, Tx
I'm one step closer to purchasing my Maxjax!
Hi ya'll! First off, I wasn't pleased with the long tube which the liftmaster would connect to, it was higher by an inch on both sides(kind of like it was bowed), so I lowered it an inch on both sides to make it look a little more level, only to disrupt the setting of the door tension a little. So I attempted to adjust the tension on the springs, but the darned things were rusted and the collar stuck to the tube~the springs were really old! LSS~ I paid someone to come out and replace the springs and the wheels/rollers! A little pricey, but I felt it was worth it!
HOWEVER~ after going in my house and coming back out when he was finishing up~ he had put the tubes back up where I had tried lowering them in the first place:shocking:! he said,"oh, you did that~!" I just let it go:(
Anyway, I told the man I was installing the liftmaster and he said, "You're going to install it?" and chuckled! I was a little dissappointed the way he said it, like I wasn't going to be able to do it, plus I thought it may have been a bear to install~ BUT!!!
Installation~It was easy!!:bounce: I was intimidated what the garage guy said, and a little by all the **** in the box and the book of instructions, but it was not difficult at all!
however, I still need to run permanent electrical wiring to it, right now it's on a switched light switch. Maybe when I run the new wiring for my Maxjax, I'll run the new outlet then.
Overall, I give it a 2 out of 10(10 being really difficult).
Dne'
38Chevy454
Cincinnati, OH
I also recently installed the Liftmaster 3800 and it was not hard at all. Just pay attention and run all the wires. Took me about 3 hours, most of that is running the wires and securing them.
tdkkart
Eastern Iowa
Now I'd like to know what the door guy thought was so tough about installing a Liftmaster??
I've installed 4 LiftMater 3800 openers at my place.
Quite frankly, if you can't figure this one out, you might want to re-consider your choice of hobbies, cuz just about anything else in the garage is gonna be more difficult.
Yes, running all the wires for the sensors etc is the most time consuming, but terribly non-difficult.
Porschedoc
There are also youtube videos walking you through each step which is also nice. I just got mine up last month for my Bendpak Midrise. You are going to love having a lift :) I was going to go with a maxjax, but didn't want to kill my other stall space as I wouldn't ever remove the lift due to constant use.
And the liftmaster is so much quieter than my belt drive overhead opener was......especially with the master bedroom over the garage.
