Light recommendation above workbench
I'm going to upgrade the lighting in my garage / shop, but the layout is a little tricky to work with. The ceilings are only ~8ft 3in. high and I have some large shelves for storage overhead, which brings that down even further in those areas.
I've been playing around with DIALux evo a little to help me out and came up with the attached lighting configuration, which gives me a pretty even ~90fc coverage on the workplane in the main garage area.
The question I have is specifically about the workbench in the pictures. Short of moving the bench to a different part of the garage, any recommendations of how I can get good lighting there? The pegboard and overhead storage are giving me headaches. I can't mount it on the underside of the OH storage because it gets in the way of the pegboard and I'd probably hit my head on it. I can't mount it on the ceiling because I put long pieces of wood up there and the OH storage would block half the light anyway. Maybe something wall mounted? No idea, need help.
Thanks!
MikeYC
Da' Burg Virginia
go to Costco, get one of the $40 dollar Feit LED 4' hang it over the WB... or you can move it around cuz its on a cord to find the best use .
Done 3800 LM. I have mine at 8 foot and brightens it up well
DC73
Lubbock TX
Maybe some type of wall mounted swing arm lamp that can be moved around as needed? I have a light similar to that pictured below mounted to a wood block on the wall above a small workbench in my garage.
DC
