jhchoppers
We bought a cheap HF hoist ($75) rated for 880Lb (880lbs with the cable doubled up and 440lbs with the cable straight). We plan to ONLY use it straight cabled and will most likely lift nothing more than 200lbs with it.
The idea was to store large objects that you don't use all the time to MAX your floor space. (ie: 200lb table saw, 20Ton shop press, fenders, hoods, bumpers.... )
Anyway, here are some pictures.
First we modified the Hoist Case to add bearings for wheels.
Using 2 pieces of angle iron, we made a simple track (2 sections 7 foot long ea, total of 14 foot of track)
Then added mounting points to connect to the joist
After a yellow paint and installed
The attic floor now has a 4 x 5 foot hole when opened and can be walked on when closed.
The system works great, I hope you enjoyed the pictures.
