Lighting advice
thightower
oklahoma
Dad built the shop I have in '81. When he built it, he installed 3 HID lights down the center, they still work well, just need to clean the difusers. He also installed 10 light sockets, which work well until the HID's come to life. I want to replace the regular lights with flurecents. Question is T5 OR T8?
roaddog359
Northwest Indiana
T 5 HO lights all the way. Thats what I put in my morton building. They are super bright and very efficient.
T
thightower
oklahoma
I had done a little homework on them. Just wasn't sure what direction I wanted to go. Thanks for the input.
Charles (in GA)
50 mi south of Atlanta
You may not be crazy about paying the price for them, but you will be crazy (happy) about the light they put out.
There is a standard T5 which is not any better of a light than a T8, make sure you are looking at T5HO lighting, such as THIS.
Charles
T
thightower
oklahoma
From the advice I've got here and the other investigation I've done. I believe I will go with the T5HO lights. With the price of them, I don't have to all 10 at one time, do a few now then finish later.
T
thightower
oklahoma
I've been searching for rule of thumb lumins per square foot in the forum. Can't find it, does any know the lumins per square foot rule?
mdale
Indiana
I was thinking that i read to use t8 if ceiling height was 20ft or less and t5 for over 20ft. Might be able to use t8 and save some money.
Charles (in GA)
Someone has suggested that T5HO is a "High Bay" light that should not be installed below 20 ft. Whether a light is high bay or low bay is generally based on its focus. Strip lights not having a reflector, have a wide spread of light that is suitable for lower ceilings. If the light had a focused reflector you would not want to use it low, as you would have a "hot spot" and not enough light spread.
I have two of the 92" Lithonia strips I bought from HD mounted over my workbenches, and they are not more than 7 ft high. They are bright but they work well.
http://www.garagejournal.com/forum/showthread.php?t=118182
Charles
new T5HO on the right, Old T12 on the left.
rosana1884
The direction of light should on the place where you want the light. T 5 is the best for your shop requirement. Thanks
