iowa4x4dieselman
- Joined
- Dec 5, 2012
- Messages
- 224
Looking for lighting layout help on my garage/shop area on a new home build. My thoughts are I would like to have a switch for minimal lighting for daily use, or just running to the garage for a tool without having to turn on all of the lights. Also I think in the tandem area there should be another switch. I would like it to be very bright as I plan on restoring my 1979 f250 in there. any help is greatly appreciated. Also, I will be having a few 220v outlets for various things. I want to be able to run a 2 post hoist, air compressor and welder/plasma cutter. My original plant was to run either the air compressor or welder outlet with the hoist outlet, as I will know when I'm using the hoist, but would like 2 separate circuits for the air compressor and welder/plasma, as I could need the air compressor to run when using the other outlet. is there any problem with doing the outlets this way? I plan for the hoist outlet/box to be in the ceiling.
Here is a preliminary layout of the garage.
. I plan to have parties/get-together's out there so fans may be necessary. Thanks all for the ideas so far.
