Hi Guys,
After rereading the "Best Light Fixture Ever!", I've decided to go with the MaxLite LSS2XT8USE4803. This inexpensive fixture allows me the freedom to dial in both the temperature and output (simple tube change), something that is important to me. Why important? Because vision and opinions can change with time. I'm also considering the Greentek GT-T8-12W1200 tube mentioned in the post (he actually suggested the 18W tube).
With the above said, I still need guidance. I’m considering 10 4’ foot fixtures and 1 2’ fixture. The tube mentioned is 5000(K) and 1680(lm) for a total unadjusted output of 33,600(lm). First off, considering that this is a working garage that is used extensively (detail work), is 33,600 a good overall number? If not, please help me dial in the number.
I also need the advice of experts as it relates to the staggered ceiling height. As you will see in the pics, on one side of the beam it is actually recessed in the area when the ceiling gets lower. Creates a lightbox effect, kinda.
Should I keep all the 4’ fixtures uniform --- same tube? And yes, above the workbench there’s also a 2’ fixture which will increase the overall output a tab.
Is the basic lighting layout shown in the diagram reasonable? The diagram shows the car pushed to the far left as is the case most of the time. When I get “busy” on the car it will be parked dead center. Ample working room on both sides.
Here's the garage basics:
1) Size: 21’ X 21’
2) Ceiling Height: Varied -- The front most portion of the garage is a low 7'5". The remaining 3/4 of the garage is 8'5".
3) The ceiling is a bright white and the walls will soon be a light gray.
4) The garage stores my 56 Chevy hotrod. It's a working garage, but decked out for entertainment. Widescreen TV, awesome stereo, black & white checkered floor -- yada yada -- you get the picture. The table and chairs shown in the diagram are of the folding type that can be stored when I have the car parked in the center.
5) The floor was installed 18 years ago and after 3 motor changes and a boatload of OTHER stuff, the floor was screaming for repair. I have been replacing tiles as time allows. That project continues.
6) My son-in-law and I will be adding outlets which includes one 240 circuit. This in addition to “Project Lighting” that leads to this post. The lights in the garage will be controlled by 2 independent switches.
The room has its challenges: a beam stretching across the room and staggered ceiling heights. Though not the best of diagrams, hopefully you will be able to get a decent idea. I will include a few additional pics to help you envision my lighting needs.
Thanks for listening!
1) Size: 21’ X 21’
so you won't blind your guests.
