Lighting Plan for 32' x 50'
BoostN
TN
Hello all,
I have a 32'x50' garage that will be wired in two weeks.. I'm trying to validate my lighting plan. I'm planning on using these fixtures:
My thought process was having 4 lights (butted together) center of the left garage door (the right side having 5 to cover the extra depth), making two rows running the length of the building. 4 together would be 32' deep (40' deep on the right side being 5 fixtures).
I'm worried if I should do 3 rows instead, or run the lights a different direction?
Inside as of right now:
Mock up from design software:
Floor plan:
Looking forward to everyone's thoughts/opinions!
sparky 1971
Central Iowa
I'd do three rows, the outside rows about 4' off the walls and another down the middle. I would also use LED tube fixtures and add a 4' to each row. It's a whole bunch easier to replace a tube VS. repairing or replacing a fixture. But, in the end, it's your shop and it doesn't matter what I would do in my building.
mm08822
All depends on what you plan to do in the shop.
Two rows will leave the sides of vehicles next to the walls rather dark. 3 rows would get rid of those dark zones and even out the overall lighting level.
Consider a few switches if you don't always need every light on.
BoostN
TN
All good info.. just placed an order for 9 8ft lights and will do three rows. I will put a shorter 4ft one over by the workbench area to help close that gap some. I will report back final pictures once I get some power turned on..
u2slow
BC
I would do 3 rows also.
Consider dropping the outboard ones down. Mine are 7-8' high; on the edge of built-in shelving, and under a beam for the mezzanine.
