Struggling to post with end of year (work and shop scramble), no lack of progress tho. Its now 14 months since taking possession of this house and I’m still not up and running, but getting closer every day now.
Got the upper cabinets made and hung on the other side of the shop, the machine shop side.
A pair to split the windows. Had to cut in provisions to allow the cabinet to fit around the conduit. Stuffed some of the things I’ve been pecking away at on it to get them off the bench.
Starting to be easier to walk around the machines now too.
Easier to walk around the shop as a whole actually.
Got a good deal on a big boy vacuum for the router table. The one I had works well but I find myself spending way too much time screwing around trying to cut little parts primarily because the table has a hard time hanging on to UV coated/prefinished plywood. This thing is a 9hp 3phase Becker Vacuum Pump. It’s footprint is actually smaller than the F4 I was using but much heavier do to the massive size of the motor.
About 850lbs I think. Used a tree strap to lift it off of the pallet.
Used the machine trucks to pivot it into position. Basic PVC ducting went quick.
Built a relay box with with a home automation controller for switching.
While I was at it, I added an electric valve to the router table so I can shut the air off to the table itself.
The spindle has a little jet in it to keep dust out on tooling changes but it’s permanently open so it’s more or less a 15 cfm leak always. Having a permanent leak which causes the compressor to cycle a lot, gets super annoying when doing stuff in the shop. Now I can turn it off.
Here’s the switches that control all this stuff. Once I get everything tuned, I’ll set up the vac switch to first turn on the phase converter, pause a few seconds, and the. Turn on the Vac. Same with off burning reverse order.
