lilscorpion
Don’t know if I’ll ever do so but I did add that last “bay” so I could expand by adding one more. We’ll see…...
That is a really nice printer farm you have there,
Are the ones in the first pic empty, or so they stack in a staircase when in use?This weeks spoils - hardware organization. I’ve been using viewtainers for years now and really like that I can take hardware to the projects especially since they tend to be all around the house.
I wasn’t sure I liked the idea of giving up drawer space so I could have labels on the storage trays but after making a sample I decided to go with it especially since I usually have to pause to verify I have the hardware I meant to grab. This should make grabbing and going require less effort.
They’re just empty. When the viewtainer is in it, it protrudes by more than half the diameter. They don’t even stack well empty since I removed the lips.Are the ones in the first pic empty, or so they stack in a staircase when in use?
Can’t take credit on the lettering. It’s a feature of Bambi’s slicer. That software makes it so easy you almost need to try to mess it up.Dayum! That lettering on your pieces is next level!
I love the viewtainers as well. I never found anything better to live in my tool bag or travel kit at work
The previous owner did that. It’s some kind of siding. He was a builder so I suspect it was surplus exterior siding from a build he did. Not sure what kind but it does look nice from a few feet away. Getting up close you can see the brad nails he used to attach it. Not very noticeable tho.Curious what material (gray) you used on the wall behind the 3D printers? That is a nice looking wall. Love the holders you made for the sanding discs too, those look handy.
I had same thought!Are you planning on putting a piece of steel under that perforated fireball plate? It would really **** if a spark or blob got into your wooden drawers full of plastic bins.
Yes! I’m planning on adding a thin sheet/tray under to catch stuff. Had the same thought - could quickly make a mess of things. I won’t use the MiG on these tops, only TIG but there’s still a chance that I could get hot metal down into a hole.Are you planning on putting a piece of steel under that perforated fireball plate? It would really **** if a spark or blob got into your wooden drawers full of plastic bins.
Unfortunately these steel utility tops are kinda an afterthought so the plan is to cut 3/4” tubing and run them perpendicular to the wall and then make little dust trays that slide in from the front that go between. The 3/4” will be just enough to allow the ball locks I have to work.I also think that you need to raise that grid top up some so you can use ball locks and other stuff in the grid holes. As I recall they need at least 1/2 inch.
Ron
What about the last row on each end? You know that's where the freak skittering ball of flaming metal is going to head right for, don't you? I know folks think there's no sparks n spatter in TIG. And very often that's true, but there's always Murphy.Not the best pic from below but you can kinda see it. I’ll make 4 low profile pans to fit below the top to catch stuff that falls thru.
Good eye. I haven’t decided yet but yeah, a bit of a pickle. The supports are Preston laying under the top awaiting fasteners. I’ll try to make 2 channels to catch debris or, if I can’t, I’ll move those two all the way to the outside. Problem with moving them to the outside is they’ll partially block the outter set of holes. Just a challenge left for another day.What about the last row on each end? You know that's where the freak skittering ball of flaming metal is going to head right for, don't you? I know folks think there's no sparks n spatter in TIG. And very often that's true, but there's always Murphy.
Why not a sheet of very thin tin under the whole thing, all the way across, curling up at the ends and back, so it'll deflect anything untoward away from the wood. Then you could slip your drawers/trays into the gaps.Good eye. I haven’t decided yet but yeah, a bit of a pickle. The supports are Preston laying under the top awaiting fasteners. I’ll try to make 2 channels to catch debris or, if I can’t, I’ll move those two all the way to the outside. Problem with moving them to the outside is they’ll partially block the outter set of holes. Just a challenge left for another day.
^^^^^ this.Why not a sheet of very thin tin under the whole thing, all the way across, curling up at the ends and back, so it'll deflect anything untoward away from the wood. Then you could slip your drawers/trays into the gaps.
That is an impressive crash for a 3d printer! Damn. Sorry to see it, nonetheless.@lilscorpion you assaulted my senses with your “organization” and “gridfinity. “
So last night I was sufficiently cow-towed in to printing a grid and woke up to this. Some how popped the clips off and ejected the glass plate out the doors. 4 years and this is the first true failed print my railcore has had. And I blame you!
/s
Hopefully it didn’t bend the Y axis linear way permanently.That is an impressive crash for a 3d printer! Damn. Sorry to see it, nonetheless.
Could yes. Hadn’t thought of that. Could probably use a galvanized sheet and screw it into the top of the cabinet then slid in the trays…worth thinking about. Good idea.Why not a sheet of very thin tin under the whole thing, all the way across, curling up at the ends and back, so it'll deflect anything untoward away from the wood. Then you could slip your drawers/trays into the gaps.
How in the hell did that happen? I’m guessing that the nozzle got attached to the grid and started dragging it around at full print speed. That’s insane! I too hope the machine is fine otherwise. Man.@lilscorpion you assaulted my senses with your “organization” and “gridfinity. “
/s
Maybe. I sense the bins would be fairly overpriced if I did the math on machine time. I could, just not sure I want to. I will likely sell jeep parts again at some point. One of the first will be an A-pillar gauge pod that works with the Switch Pros setup. Need a cleaner way to mount boost and intake temp gauges and needing to do so was the primary driving force for buying 3D printers in the first place.Is the plan to start printing for sale after all this as well or do you have three with a temptation for four just for your own projects? It's a super cool setup either way. I love all your organization. You make me consider more than one cause I am not sure I am going to have the patience for speed of just one when I get underway.
Great question! They were supposed to start again about now but I’m really behind on getting the shop (and inerrior mods I promised the wife) done. I have a pile of parts for my daughters Hemi JK on a pallet in the middle of the shop floor. That’ll be #1. Then I need to refresh my son’s jeep - powder coat the calipers on his Dana 60’s, redo all the powder coat on the suspension parts, and get his gauges up on the a-pillar as well. Then there’s mine. Minor touch up to powder coating…then I wanna to put a boosted LS in it. Something that gets 30-40 smiles per hour if you know what I mean.Sooooo, when do we get back to cool Jeep modifications????
I might make some. Not very high on the list. Main issue is I can’t see where having the holes is a big deal (for me). If I need a bench without holes to do stuff, I can use any of the 40’ of bench space I have on either side of the shop. I do get how someone with limited space may want to utilize plugs like these to convert their welding bench to a general purpose bench. They time it would take to plug and unplug doesn’t seem worth it
Thank you for the shout out!
I also work in the technology sector and as you said hands are kind of important with a keyboard. That work is a hobby for one that if I allow it to harm me in that way it could ruin my hobbies and my income. Now I am going to redesign my shop table layout around an SS, even if I can't acquire one just yet instead of my existing contractor saw.It’s kinda like insurance that you never hope to you’re and, if you’re lucky, you get to complain about having to have years down the road because you never did need it.
Reality is however, that if you spend enough time on the saw you’re really just increasing the risk of having a moment. And that’s all it takes to end up injured in a way that could be life altering. I’m in technology and typing is kinda important. Typing with 9 or 8 fingers could be done but would be an adjustment and might impact my ability to work. So I considered saving $1k in a hobby vs the consequence of impacting my ability to pay for said hobby…an easy decision.
Do it. They’re really nice saws. I’ve been very happy with it. I can count 10 times my saw has come in handy and/or never let me down.I also work in the technology sector and as you said hands are kind of important with a keyboard. That work is a hobby for one that if I allow it to harm me in that way it could ruin my hobbies and my income. Now I am going to redesign my shop table layout around an SS, even if I can't acquire one just yet instead of my existing contractor saw.
Heh…mine too. Each thing I organize makes me want to organize 3 more.You're playing hell with my ocd, keep up the good work!
