Ok, so I farmed some of this info from a previous post on the same compressor. All the photo's that had been posted were gone, and I think other member replies as well. I am really hopping someone can help with my issue. I will try to get pictures to post soon. There is some stuff in the way I need to move.
So the compressor I have is a Lincoln pump Model 9201. The model number on the data plate of the pump says 9201, and on the side of the pump case is has the number 5515. The serial number says 310-21, and another number below that is 369871-L. I am beginning to think that means its a 310 pump, ROC (record of change) 21. From looking at other stuff online I think this is a quincy 310 pump, is that correct? Am I correct on the model of this pump?
The tank to the compressor is stamped with a date of 1940. It's a two stage pump I believe, and it runs very quiet. I am looking for a manual or a source for parts. The valve thing at the top of the pump leaks air when the compressor is running. I believe this is a compression relief valve? It was working fine, and would let of some air when starting to run and then would stop. The air line goes down the side of the pump to a square block which has a bolt in the center with a spring behind it, behind the spring is a small steel ball about the size of a BB. I have had the unit out of the case. It has large O-ring seals around some sort of pressure valve it looks like. I am guessing this is not functioning properly? the air leaks from something that looks like a sort of valve on top of the cylinder head.
Anything anyone can tell me about getting parts in the future or at least to fix that leak would be greatly appreciated. It has been completely stripped and restored by a friend and looks beautiful, it's quiet and I love it as I can run it at night and the neighbors don't complain.
