Linesman pliers or all purpose?
grantw
Bay Area, CA
This is off topic but not really only because it was mentioned above via the back stab wires... ...butif the back stab wire method is such a bad thing why isn't it eliminated? If the wires are prone to coming loose out of the back it just seems silly to me that one would use it...
-Nigel
Exactly.
For clarity, "back wiring" is different from "back stabbing".
Back stabbing is a horrible idea, but somehow it caught on in the residential market. I'm most familiar with it in track homes where the lowest bidder is in charge. It's fast and easy to strip a wire, shove it in and be done. Somehow, leviton got these pieces of **** listed and that is how the sh*t stuck to the wall. I mean, look at this: http://www.electriciantalk.com/atta...fferences-our-electrical-systems-dsc03713.jpg Do you trust 5-10 of these in a daisy chain to transmit 12A to your vacuum or clothes iron?
Back-wiring is an actual clamping mechanism where you do not need to bend the wire. You only need to screw the clamp shut. I'll trust a full 20A through a clamp connection all day over just one backstab. https://www.handymanhowto.com/wp-content/uploads/2011/01/DSC03649.jpg
ctfjr
Basketball Capitol of the World
All pros I know use their linesman pliers for just about everything, including stripping solid core wires. A good set of linesman pliers will outlive you.
This ^^^
I've wired my two houses that I built and I can't imagine what it would be like without a good linesman pliers (I also use Klein)
SuzukiGS750EZ
Can you loop wire before attaching to the outlet or pinch it shut on the outlet with lineman?
SuzukiGS750EZ
Just got the 7.5" Channellocks today. Perfect size for me. They seem like they'll handle well for what I need. Although I'm the nines would be just as good.
SuzukiGS750EZ
Curious as to if there is a functional reason they're ground crooked? I don't care, just wondering...
Fixed
Ontario, Canada
They're done by hand. I usually look in the store before buying. However it's rare that they're perfect, and rare that it is a functional issue
