Lisle 58430 Shaft type seal puller
oldtools
This tool work quite well. Save alot of time. I just wrap some tape on the hook that will contact the crank to prevent scratching.
dudutzu905
you don't actually pry on the crank, you just slide it by, and then you pull on the seal, there is not any force against the shaft, I've used a bunch of times, it works great!
Jarhead0408
Who knows?
Veeeery cool. Thanks OP!
I wonder if they sell this at any of the parts stores? I'll have to check.
jacked_72
Here's a video I shot of the Private Brands set up pulling cam seal on a Toyota V6 engine. It worked great for pulling the seal, but there was some lip on these Toyota cams that prevente me from driving the seal in easily.
P
PoorOwner
CA
OK .. I'm going to get one. I'm sure it is still safer than screw driver and dental picks
braol
Manchester, Tn
I saw this on the SO truck today. And after seeing the price online I am very skeptical. At less than $15 I doubt the "hooks" for pulling on the seals are hardened and will likely bend. But maybe not, IDK.
GTA Matt
Zebulon, NC
Like I said earlier, I've pulled literally hundreds of seals with mine. Not one problem, still on the original end. I think it even came with an extra too.
signcrafter
I'm just a home guy so I don't use mine much but it works great when I do use it. I don't know if the puller is hardened but it works fine and comes with an extra also.
WVBrady
WV
For extra safety against marring the shaft, you can cut a little section out of a two litre plastic pop bottle. (soda bottle) :)
andywander
Hardening the steel wouldn't prevent bending-you have to use a stronger steel for that. the hook looks like some kind of spring steel, which should work well.
It looks like the one in the video is assembled wrong(?) Why would you want the nut that holds the hook on to be on the shaft side?
duanedragon
Same thing I thought. Switches around easily. It's assembled incorrectly from the factory.
AJH
Madison, WI
I've used this tool on a number of Subaru cam and crank seals, and it has indeed worked as advertised for me. It can be a little tricky to get it into position in an engine bay, but I've eventually been successful.
czgunner
WY
That Lisle works pretty good, but the Private Brand kit linked is awesome. It has saved me SO much hassle and time.
impactsocket
Will the Lisle 58430 seal puller remove a axle seal?
Ramblin Man
Middle Tennessee
I have this tool also, and I like it. I try to insert the lip of the puller between the rubber of the seal and the metal part of the seal, to stay away from any machined surfaces. Most of the time I can, but when I can't, I have never had a problem.
metalhead212121
I have this tool and used it on a crank and cam seal that were ROCK HARD. The seals DID come out. Like others have said.. the tool works.
Will the Lisle 58430 seal puller remove a rear main seal?
Again.. I used a similar tool like this for ROCK HARD rear main seal. It worked.
Skip going out on a friday night one time and buy this tool.
YOU WON'T REGRET IT!
MattPersman
Indiana
That rear main you unbolt all those 10mm head bolts on the retainer and it comes with a new retainer.
impactsocket
jobo1004, how did you end up removing the rear main seal from your Honda Civic? What tool did you use?
