I had the idea of taking a set of sockets and drilling/tapping holes into the flats as a way of achieving three things:
1. A Nut and Bolt retention system where a dropped nut or bolt is a major problem
2. Being able to lock down a socket onto a bolt or nut during removal where the socket will not fall off the nut or bolt when the ratchet is at an angle (think wobble extensions/u-joints/extreme angles/etc).
3. Being able to remove stripped or damaged nuts and bolts
Well, I think I've figured it out. I have the provisional patent and functionally have had a set created.
Drilling something as hard as a socket without it cracking and then being able to tap it without the tap breaking has been quite a challenge without it becoming prohibitively expensive; but we've done it!
Full 3/8 set:
4mm set screw, a 3mm set screw would be nearly flush.
Completely rounded nut as a test subject for removing stripped nuts and bolts:
Post removal:
I'll be aiming towards pricing these at ~$150-190 USD for a full 3/8 shallow set. Chipped chrome and no warranty should be expected.
Feedback is welcome.
Full 3/8 set:
Post removal:
