Long 1/2 in drive ratchet
Jwych
Sioux city Iowa
Looking for a ratchet that's 24ish inches long. I need it to be fine tooth and flex head. I've looked at the Snapon version and can't justify the $200+ It would cost for the amount it will be used. The Titan model doesn't have fine teeth so that's out. I see ez red has one but unsure of the quality. Will use this ratchet for one purpose in a very tight spot not very often so don't need perfection just fine tooth and mediocre :) any suggestions ?
stonesfan68
Houston, TX
For what application do you need a fine tooth 1/2" ratchet that is for a 24-inches long?
nicksnothereman
In the Mojave
Ez red is fine. Kobalt would be more. There are other rebrands of these taiwanese ratchets (like the ez red) but I don't keep track of them all besides ampro. 1/2" means torque shouldn't be a problem with any of them unless there's a mfg defect which aren't typical with this stuff.
J
Jwych
Sioux city Iowa
Ruger_556
I need this for air bags on semi trailers.................. the bags we use have tall ports on them so i am unable to get an impact into the space to tighten the nut down on the port.
Oh those... Yeah those ****...
tbaggz
air ratchet work?
Or make your own from a breaker and a ratchet,frankenratchet, from hf or similar.
J
Jwych
Sioux city Iowa
air ratchet work?
i dont know if i could even get an air ratchet up into the space. its pretty tight quarters in between 2 cross beams on the chassis of the trailer.
the thing is the rear bags are usually pretty simple to remove and replace. but the front bags are often a pain in the **** because its boxed in between the front beam, and cross beams of the chassis. not much room above either because of the floor of the trailer.
kball
SoCal
Not as long as you want but the Gearwrench 120 tooth might work well for you with a small cheater pipe.
Verg
To close to DC
My SO truck guy sold me SLF80 24'' brand new for $100 cash. when i bought it i was thinking this thing is going to be too big and clumsy for dooing anything; I was totally wrong. The 2 footer has been the best ratchet i have owned by far. For some reason the 80 tooth mechanism is just way sweeter in the 1/2's then the 3/8s, pure butter to the fingertips. So truck man had a used one with comfort handle for 100: so i got another one (had to share the wonder). Personally i would go for a professional quality tool for an extra long 1/2 ratchet. If you cant haggle with a S/o guy; Ebay? I was going to buy a SK tuff 1 (72 tooth) or Armstrong (60 or 72 might be the maxx series) 1/2 ratchet if i did not get a deal on my s/o first.
92integra
for 1 i have the ez red 24inch ratchet and its great for the money, i bought it used from my snappy man for 30 bucks........... idk if those bolts your working with will spin off ater being broken loose but if so maybe check this out http://www.amazon.com/dp/B00FAHA8SC/?tag=atomicindus08-20....................... it works with their clutch fan tool might be useful in your situation
92integra
also if clearance is really an issue the matco 1/2" is MUCH THINNER than the SO
bob15
Northeasten, CT
Have you looked on e-bay for the snap on?
They are a lot cheaper than your $200+.
cassidy
Jeromesville, Ohio
Cornwell has a fine tooth 27" flex head ratchet. And it seems to be cheaper than other tool truck brands. I have a few cornwell ratchets and I really like them. http://www.cornwelltools.com/webcat...2”-Drive-Fine-Tooth-Flex-Head-Handle-Ratchet-
I have this ratchet, it is a nice ratchet but I am too am a diesel mechanic and I have broken this ratchet 5 times in the course of one year. No cheater pipes or anything, when I put a lot of torque on it the thing just locks up. I traded in my 24 inch snap on for this when they came out because it was longer and still fine toothed, wouldn't do it again. Now the cornwell truck hasn't shown up in 5 months, it's a good thing I live within driving distance of the Cornwell headquarters and warehouse so I just go there and they replace the whole thing. The people in the warehouse said they see a lot of these coming back. I'm going to buy another snap on.
jrobb316
WI
I got the snap on Very long flex with handle on ebay for $115. My snap on guy (who is very cool) dropped a new head set in it for me, just like brand new. I would buy this ratchet again if I had to.
jrobb316
WI
Ask your snap on dealer if there are promos. I have found there are a lot of promos they don't necessarily advertise. I managed to score their new 36" breaker bar for like 50 bucks off.
shockwave
Marietta,ga
If you have a snap on dealer usually once a year they have a special on them I got mine for 99 bucks last year this way
Zeroek
Indiana
That *****. I want that ratchet. I wish they made it in the regular 30 tooth design. I'm not a big fan of the Cornwell Fine tooth ratchets. In my situation it may be a good ratchet since I work at Honda.
92integra
zeroek i guy i worked with had the 27inch cornwell aswell and it does like to lock up and not switch directions, if you dont mind tapping it on the floor a little to get it to switch directions then go for it but i think its **** and would stay away.
cassidy
Jeromesville, Ohio
Yes stay away, I bet even loosening a lug but on a car would lock it up. I wasn't abusing none of the ones that broke, total garbage.
dragonballz
Massachusetts
Dont buy the harbor freight breaker bar with ratchet. I bought it to do alignments and it jammed up. I got a warranty replacement and it jammed again. Now I have a jammed ratcheting breaker bar that is now just a breaker bar
