Longest pattern combination wrenches made ?
Tonyuk
Scotland
Longest i have are the extra long Toptuls, they're very good.
Do you have a lift to work with? If not then i would stay away from extra long combo spanners, you just don't have the room to use them lying on your back with the car on jackstands.
Snap-on standard length are probably the longest i would recommend.
Dave455
Sussex, England
If you want a long combination wrench, then my first thought was the extra long Hazet (600LG) as well. Looking at the figures, it is, at 305mm for a 17mm, but that’s only 7mm more than a Snap On.
Good advice from the other guys though. There are going to be many situations when you just can’t use these!
rmsg0040
Toronto
^^Ditto, with no room to throw some tools just won't work
ssdave
Eastern Oregon
Here's a comparison of the lengths in my toolbox:
bob15
Northeasten, CT
Mac & Armstrong used have an x-tra long wrench (Mac might still have them). I think the 9/16 was 10 or 11 inches long....
dutchgray
Dorset. England.
The Toptul 19mm combination wrench measures 348 mm = 13.7"
The Hazet 19mm is 335mm = 13.2"
I only checked a couple, looking more the Hazets are longer 13mm and smaller, the bigger ones Toptul are longer, but the Hazets are made in common sizes up to 32mm, Toptul only does to 19mm.
The hazet 10mm is 20mm longer than the Toptul.
CR888
I got some double box end ratcheting wrenches made by Mako (actually Kabo) that are XL. The 1/4" is 210mm (8.25") & the 3/4" is 400mm (15.75"). But these ain't combo style with an open end.
mudflap
cincinnati,ohio
Rickster
SE PA
I have a 3pc Cornwell set of combos sitting around. They're marked -L, the 1/2 is 9" long and the 5/8 is 10 3/8" long with the 9/16 right between them. If they have a -L gotta believe they have a -XL somewhere.
kythri
Lebanon, OR
If I can add an additional qualifier:
Who makes extra-long in both SAE and metric?
The 600LG from Hazet look nice, but they appear to be metric, only.
Chalk up some more regret at not jumping on some Armstrong stuff sooner. :(
Ton ton
Page County,VA
All I need is metric. I have more SAE sockets than I want to think about.
Wamsutta
Amarillo, Texas
All the truck brands do. I wouldn't recommend Matco's version though.
