Looking for a specific rethreading tap
T444e
I believe Lang has a thread restorer kit containing 5/8-11 tap. I don't know if they sell individual pieces.
Mgdoug3
KY
I rebuilt a pulling engine and saved a 5/8-11 head bolt to make a thread chaser out of. I stuck it end my mill and used a ball end mill to cut 3 slots in it by eyeballing. Works great to clean the threads out.
Hakeem
Chicago
The 48 piece master set contains a 5/8-11 die but not a tap.
Cut some slits in a high grade bolt? Depends on how bad the threads are
I would do this. Take a grade 8 bolt and use a cut off wheel at a negative angle to cut 2-3 slits in the fastener
Grant Gunderson
Bellingham, WA
A Thread Forming / Rolling tap is ideal for sizes that the rethreading taps are not available in. Unlike a standard taps these do not cut threads and remove material but they form it into place and actually create stronger threads so they are perfect to use as thread chasers
carbon rethreading tap: $14.63 344321 china carbon steel plug tap
hss steel: $46.60 343013 taper tap hss
Tacoma Screw
in stock
1 800 562 8192
C
Coach James
Sandhills of North Carolina
Thanks for all the replies. I'm going to try the grade 8 bolt method first. I'm still learning a lot of this metal working stuff so if I mess it up, I'll still learn something. This is for a bunch of rusty nuts that came off a 1980's Toyota pickup my son is restoring. I am cleaning up the 5/8 nuts and bolts partly for the fun and partly for the practice with thread chasers.
Coach
WWheeler
Middleofnowhere USA
Coach
Any threads on that Yota are definitely metric unless someone's tapped/die'd them different.
BTW, this is a great book for those pickups. Highly recommend saving your son a copy while someone still has it up.
How to Keep Your Toyota Pickup Alive: Step by Step Procedures for the Compleat Idiot for 1975-1987/2 & 4WD
If so inclined the physical books (used) can still be found but they can fetch a pretty penny.
C
Coach James
Sorry, I should have elaborated. The bolts were for a wood bed that the previous owner made and put on to replace what the truck came with. My son bought the truck a few months ago and took the wood bed off as it was in terrible condition. He is in the process of fixing the truck up to use for camping and off roading.
Coach
  • Like
Reactions: RTM
C
Coach James
Thanks for the link! I downloaded and saved it and just sent a copy to my son.
Coach
