looking for advice
csciara
i have a 32x50 block garage that is 110' from the house and im going to bury a gas line, water line and power to it. im looking for advice on how deep i need a trench and what i can throw in the same hole, would like to put all in the same hole at difference depths. for the power im upgrading the house at the same time to a 200amp service and looking to put a 100amp panel in the garage. what size conductor do i need to bury (2/0)?, what size gas line?, im also putting in some other cables in the hole for internet (cat5) and another cat for security cameras
im in the pittsburgh pa area as far as frost line
i know im asking alot, any help would be appreciated
Thanks, Tony
G McKay
In the garage in Bremerton
Codes differ from area to area/city to city. For instance: The depth code in one city may differ from the next city over. So, you really need to check with your local codes. I would think all you have to do is stop in at your local city hall and ask the questions you need to ask. Good luck.
Lassen Forge
Go to the city and see what they require. We cant tell you that here, unless we live where you do.
Here, we can't run Electrical and Gas in the same hole, and they must be separated by 18" horizontal and 6" vertical. We could run Cat-5, Cable TV, and Telco in the electrical hole, but it must be in separate conduit, and if being adjacent to your 240 or 480 feed to your building - too bad. Our *actual* frost line for utility burial is 20", our legal one is 30". Water in its own hole, approved materials, at or below the legal frost line, same separations apply.
I live over 2000 miles from you, so if you try to use my county and state laws and climate conditions, you may be fine, or may generate one hell of a fine, or energize your water lines and kill your kid when they go to get a drink of water at night, or burn the house down... yeah.
This is stuff to talk to the county about, and find out what you need to do for your area, not a huge forum where, honestly, someone could be talking out their backside and you would not know...
