Looking for automotive themed cabinet pulls
A34
Ball Ground, GA
Guys,
I'm looking for some automotive themed cabinets pulls. Any recommendations on stores that have them, or something you've made yourself?
I'm a Mopar guy, so Mopar related stuff is preferred. This is going on some nice wood cabinets in my office.
Thanks!!
:beer:
kelpaso1
MEMBER EMERITUS
New Brunswick
Here's mine I made.
Bench
Wrenches. Stubby wrench set (used four of them) I got at Canadian Tire for 9.99.
Right one is a camshaft from a snowblower engine. Left is the gears out of an ATV winch.
Sparkplugs
kelpaso1
MEMBER EMERITUS
New Brunswick
I used some brushed steel pulls and cut the center out and welded the "pegs" to my handles. The wrenches I JB welded so I didn't discolor them by welding.
Wood'nMetal
PNW Oregon
For my son's room, he has several big drawers. I bought some chinese 1 1/2" wrenches and drilled holes in them and mounted them on standoffs as drawer pulls.
Modern Jess
Bay Area, California
Interior dashboard knobs and switches can make really nice cabinet / drawer pulls with some thought.
Not Mopar, but I used some scooter cowl latches for my scooter-themed shop. They already had a rod on them, I just cut the rod, threaded it, and put a small spacer between the latch and the cabinet face:
Kaizen
New England
for my kitchen drawer pulls I used some spikes from the beams I was using for a faux post and beam feel. I ended up drilling and tapping them and screwing in from inside the drawer. above are some really cool ones but ask everyone how they did it. on mine I failed at mig welding studs to them as the difference in metal caused the weld to not heat up bot well. also tried epoxy and did not hold well.
a tig would have been the best but not in my arsenal. whatever you do order a few extra to play with if you make your own.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Check with an RC place and see if they have pistons you can buy. For my nephews cabinets, I made him what looked like pistons. It didn't take very long to turn them in the lathe, then a few minutes in the mill to cut in the skirt and valve reliefs. Everyone thought they were out of RC cars.
Or hit up a junkyard, and get some window cranks out of a few cars and utilize those.
kbs2244
Valves.
From curb side lawnmowers or a junkyard visit.
Someone with a lathe can cut off to length and then thread the stems.
NUTTSGT
Northern Central Ohio
I used some cheapo china wrenches for my locker at work. I welded some square spacers on one side and bolted them on the backside through the doors.
strength_and_power
To take this a step further using the standoff idea, take some mopar logo images to a fab shop with a laser and have them cut them from brushed or polished stainless. Also have them put the holes for mounting to the standoffs.
I also had a friend who did something similar and used an off the shelf pull but had a backing plate lasered out and it sat against the cabinet face. Looked really good and had a lot of detail. The material was pretty thin so the laser cost was negligible
Big Bad Dad
Southwest/ Central Va.
If you don't mind them a bit large, try finding some old Mopar hub caps with the centers that unbolt. I have a set of Pentastars from an 80's Chrysler I have been holding on to. Also from a 70's Dodge, I have a couple with the Dodge "Fratzog". It would be really cool to get some 3 prong spinners from mid 60's Sport Furys or Chargers, etc...:thumbup:
