I’m looking for recommendations for finishing the concrete floor in my new shop.
Current planned uses, subject to change:
The floor part of that project took 6 weeks and 166 labor hours. And after all of that, we ended up moving to a different house 7 years later. I don’t want that big of a flooring project this time.
Requirements for this new floor:
Please share your thoughts!
- Motorcycle parking, maintenance, projects. (If necessary, motorcycle parking can be on clear vinyl runner material to prevent tire stains.)
- Metal projects. Not sure what yet. Cat statues? Motorcycle frames? I have a MIG and am thinking of buying a plasma cutter and TIG.
- Some woodworking / carpentry. Maybe furniture refinishing. (I know almost any floor will need to be protected from chemical strippers and wood stains)
- And a bunch of small, cleaner stuff that has no impact to floor type.
- needs to look nice
- can’t be slippery when wet due to motorcycles
- easy chemical cleanup (oil, brake fluid, cleaners, etc.)
- color stable – no yellowing. This shop has big windows.
- metalwork friendly. If I have to use a welding blanket to protect it, I will, but would prefer not to. I know this is a tough one, so it’s optional. (the VCT definitely was not)
- I plan to have a motorcycle lift table in the shop, and might want to cut the concrete in the future to drop it to be level with the floor, similar to what @ekraft84 did. Post with pics here, under the racing pics: https://www.garagejournal.com/forum/threads/motorcycle-roadracing-garage.203554/post-3163629. So it would be great if the floor finish is repairable after a project like that.
- The concrete was poured 9 months ago. I think it’s fully dry by now, but that’s a question for the experts here. It has vapor barrier plastic under all of it except the outer edges where there are footings. Picture below.
- Most of the concrete is ~4 inches thick, over ~4 inches of gravel. The edges/footings are between 18 inches and 42 inches deep. Picture below.
- The floor surface was hand-troweled 3 or 4 times when wet, and then machine-troweled the next morning when mostly set (long story). So it’s smooth, but not as perfectly smooth as normal machine troweled. Picture below.
- There are a few cracks. I’ll need to know what to do with them based on the finish I choose. Close-up picture of one below.
- The space will be insulated, finished, heated/air-conditioned (mini-split).
