Looking for Idea's
slidewayes
hesperia Ca.
I hate doing / no good at drywall looking at new Idea's for my ceiling living in the So Cal desert cold is not a problem Hot I can handle but I would like to separate the shop from attic pictures are good thinking of just an alum. foil paper ?
sublime68charger
SW Wisconsin
Attached to the house or not and size of garage!
how about just white styrofoam and run a wood 1x4 every 24" to take out the sagging?
That's my rough at the moment plan for my place
Zeke
Better than nothing. When you say 'foil' I hope you're not thinking of the stuff at the grocery store. Not a very good value. You can find some salvage material to make your ceiling out of. Foil over foam and used foil side up on flat roofs under the roof membrane have very good effects.
yaidunno
WI
Garage size and budget?
My vote would be tin with blown in insulation.
slidewayes
hesperia Ca.
30x35 1050 sq ft when saying foil I'm thinking what you would see in a commercial /tilt up build. Cost is not the deciding factor clean +Quality is
spectral
Brisbane - Australia
I'd go aluminum composite panel in gloss white. 3mm gap filled with black silicon. Fasten with stainless button heads. Sweet :)
ddawg16
S. California
Cost per sq ft, drywall is your best value.
Drop ceiling? Like in your school?
Corrugated steel?
What ever you do...take into consideration what would happen if you had a fire.
Zeke
Corrugated steel?
Any ceiling except a highly flammable one is a benefit in a fire.
What's the budget here? I think dropped ceilings are great. Lots of panel and lighting choices.
When the 'industrial' look of removing the panels and leaving the grid in place came out, I liked it but realized it wasn't the most practical thing to do.
But when are designers practical?
Bib Overalls
Jonesboro, Arkansas
I noticed some OSB roof decking at Lowes with reflective foil on one side. Think you can also get dry wall with reflective foil on the back side. Your ceiling framing looks pretty stout. However, you would get a better result if you strapped the ceiling with 1"x4" boards 24" on center for 5/8 thick drywall which is code for garages in most places. If you use 7/16" OSB decking you should be able ******** 24" centers although I would prefer 16". If you decide to sell an astute buyer's inspector will pick up on non-conforming ceiling material and you may be required add 5/8" firewall rated drywall as a sales condition. I'd bite the bullet and do it now.
SilverSS1969
A guy on this forum used the vinyl or aluminum soffit material on the ceiling of his garage. Looked very clean, not sure on price per sq foot.
Dan in Pasadena
Pasadena, CA
4x8 sheets of insulation with the aluminum foil skin. It's not any worse at supporting fire than those exposed joists. Plus, it's reflective, you can **** the sheets edge to edge and use those roofing nails with the colored plastic washers on them to hold it in place. Easy peasy.
EDIT: Oops, guess I was just a little too late in posting that. Never mind!
slidewayes
hesperia Ca.
The lift is made by BESTWAY HYDRAULICS 2500 lbs cap. can spin 360 at any height maid in so. cal. they don't answer the phone or emails But if you can get a hold of them it is a grate lift
