Looking for screwdriver that can store in it...
chrisnazzy
Arizona
a phillips bit, a flathead bit, and a 10mm 1/4 socket.
Anyone seen one with enough space in it for these 3?
I don't know if it's maybe more than you're looking to spend but the Snap on ratcheting screwdrivers have a bit storage cavity that could easily hold the bits you describe plus a 1/4" socket adapter bit and 10mm socket.
mikebaker1129
Huffman,TX
If so,there is always the Williams version for $29.
chrisnazzy
Arizona
True plus there seems to be hundreds listed on eBay at any given time and many sell for less than full retail.
I just went out and checked the fit in mine. If you clip the 10mm socket on a 1/4" socket adapter and drop it in first you can fit at least 3 more bits in there without interfering with the cap. I tried the 10mm/adapter plus five bits and while I could get the cap screwed on it didn't work out so well. Once I unscrewed the cap everything was initially stuck inside because the cap had press fit everything in there tightly.
So a 10mm socket with bit adapter and 3 additional bits no problem!
Roundhouse
I have a couple of these
I can test mine to see if those items will fit but I’m pretty sure they would
