Fordguy1964
OK. I'll admit that the "dropped compressor" thread got me a little scared. I got the compressor that I am using 3rd hand. It has a drain in the bottom but had gotten clogged several times with rust as I am draining it. Tank is rusting from the inside out. So.....
I am considering a new compressor. I currently have a single stage with a 80 gallon vertical tank. I need and use air for painting projects, running air tools, light sandblasting in a cabinet etc. Since I don't have a lot of money I am considering the offerings at HF. What are the opinions of the group? I would like to hold 120 PSI. What should I be looking for and what should I avoid? I work in the garage daily in the summer and the compressor will see a lot of use. I am going to cut a hole in the side of the old tank to ensure it is not resold to some unsuspecting person and have it blow up on them.
Is there another route other than HF that I should look at. Money is a consideration. Power is 220V single phase. I like the ability to go to the brick and mortar store and lay hands on them but will order online if I can get a better unit and price.
Thank you !
Thank you !
