Lowering speed - Hein Werner
BrianJ
I have a Hein Werner WS 1.5 ton model and this jack lowers so fast that it's scary.... Anyone know if the descent rate can be adjusted?
Hiball
Missery
Nope.. Not without some serious re-engineering, Are the Gears bend/binding and not preventing you from smoothly rotating the handle? Any binding will make it herky/jerky and harder to control.
BrianJ
Nope. No binding that I can feel. Any areas to spray down to see if I can 'smooth out' the handle? BTW, it's a 'T' handle with release dial in the middle.
whateg01
doo dah, kansas, usa
I noticed that on the newer 3T HW I gave to my dad. My 2T is better. The best advice I can think of, though in my case it only helped a little, was to make sure not to tighten it too much. That way it doesn't take as much force to open the valve and overshoot how far open you want it.
Dave
Spacey_G
I have my father's WS 1.5 ton that was purchased probably sometime in the early 80's and it will lower very slowly if I just crack the valve. I'm not sure what would be different with yours.
whateg01
Some HW jacks (and apparently some others, as mine is a rebadged Lincoln design) are hard to just crack the valve on.
Dave
BrianJ
Dave
Thanks for this. Taking this advise resolved my rapid descent issue.
After I sprayed the area down with some lubricant, I closed the valve lightly, which made cracking the valve open easier = slow descent.
I guess I was just used to cranking down on the valve tightly.
