Nope. No binding that I can feel. Any areas to spray down to see if I can 'smooth out' the handle? BTW, it's a 'T' handle with release dial in the middle.Nope.. Not without some serious re-engineering, Are the Gears bend/binding and not preventing you from smoothly rotating the handle? Any binding will make it herky/jerky and harder to control.
I have my father's WS 1.5 ton that was purchased probably sometime in the early 80's and it will lower very slowly if I just crack the valve. I'm not sure what would be different with yours.
Thanks for this. Taking this advise resolved my rapid descent issue.make sure not to tighten it too much. That way it doesn't take as much force to open the valve and overshoot how far open you want it.
Dave
...I guess I was just used to cranking down on the valve tightly.
