Lowe's Clearance Thread 2015
Status
Not open for further replies.
gumme
Style Selections 60-in W x 72-in H Sliding Shower Door
Item #: 150457 | Model #: 1508F-TNG
$31.13 is the lowest I found, several in the 62.00 range .Was 249.00
stonerado
Owasso, OK
I actually bought one when I found it for $16.12 like I mentioned in my post. I ended up returning it after finding numerous reviews about it shattering for no reason.
sseiyah
Good deal. Show online for 588.00
Per Lowes.com, these show the $294 price:
Store #1861 - CAPE MAY NJ - QTY 4
Store #2552 - RARITAN NJ - QTY 2
Store #1656 - HILLSBOROUGH NJ - QTY 2
Store #1676 - HOWELL NJ - QTY 2
Store #1149 - LAWNSIDE NJ - QTY 3
Store #1608 - TOMS RIVER NJ - QTY 2
gumme
After reading the reviews, I agree with you. I would not recommend buying this.
JR4815D2
___
not sure if this was posted
Blue Hawk Electrician's Tool Set
Item #: 471888 | Model #: SWBHTOOLKIT
9.98
JR4815D2
___
DEWALT Drill/Drive Set with Contractor Bag
Item #: 752219 | Model #: DWA2LOBAG80
19.97
BryGuyTsi
Kobalt 5 piece Pliers Set
$9.98
Item #: 464614
Model #: 55754
Includes 6" long nose pliers, 6" diagonal pliers, 6" slip joint pliers, 7" linesman pliers and 8" groove joint pliers.
Set also comes with a 6" Adjustable Wrench in the package at my local Lowes.
stage20
pcola FL
$9.98
Item #: 464614
Model #: 55754
Minus the dikes I tossed out everything in that kit. The grooved pliers never stayed tight. I could have tack welded the nut but I just didn't find them comfly. I think the new red handle Harbor freight set would be a better choice imo
SRMX
547020 Dewalt 20v 4.0AH lithium battery $55.20
Check your local prices
Thanks for the battery tip! Appreciate it. Found one for like $37 +tax. Store only showed one. I looked everywhere for it and couldn't find it. I then went to the upper slider closest to where the battery should've been and tried to look from under the shelf as well as I could (without getting up there to open the slider) to see what was in there and saw what appeared to be 2 Dewalt batteries. I figured there was a pretty good chance that one of them (if not both) had to be what I was looking for. I asked the tool guy to get something down from the upper slider and of course he wanted to know what it was. I told him and he did his best to take my attention off of my original request and wanted to look in the same places I already had. So we went through that 10 min routine and then he finally said it probably didn't exist and tried to get me to buy one of the 2 packs on sale. I politely declined and asked if he'd take a look in the overhead like I had originally requested and sure enough, 1 of the 2 batteries was the "missing" one.
So I don't know if he knew it was up there and didn't want me to have it or if he was just trying to avoid having to get a ladder and climb up there if possible thinking he knew better or ??? but I do find it interesting that there seems to be PLENTY of items with only 1-2 in stock at full price still sitting out on the shelves but the higher value/more coveted items that are on a deeper than normal clearance are conveniently off the floor and sitting behind closed doors in the overhead.
Anyway, all-in-all it was a successful trip and I got the battery was looking for so thanks.
Premium08
Littleton, NC
This deal was to good to pass up.....
Sent from my SCH-I535 using Tapatalk
JR4815D2
___
Holiday Living 6.5-ft Pre-Lit Seneca Pine Artificial Christmas Tree with Color Changing LED Lights
Item #: 672838 | Model #: W14L0441
50.00
rednotch
south nj
Anyone looking for those
DEWALT 20-Volt Max-Volt 4.0-Amp Hours Lithium Power Tool Battery
Item #: 547020 | Model #: DCB204
$27.90 each
4 Available in
Lowe's Of Prattville, AL
2307 Cobbs Ford Road
Prattville, AL 36066, Store #1181
Good Luck on getting them
Found 1 in stock, the only store that had it around here. Checked open stock and asked the tool guy when he came up, Gave me the normal we don't have it deal and walks away. I slide the top stock door open and see it clear as day but can't reach it . Lady working the pro desk yelled over that I couldn't use the ladder as I was moving it so they had too call the guy back over. He wasn't happy. No go on the palm sanders in any stores near me, but they did have the bosch impact from a week or two ago on the clearance rack. Box marked no battery and they still wanted over $70 for it?
Spn1025
New Hampshire
Lazy douchebags...
Please tell me you called him out on it.
I'm used to it. Got one of the 3 amp Dewalt orbital sanders for $17 today (display model) and had to talk to 3 different people in hardware to finally get it.
1: we don't sell display models
2: we're using that as a display for the new model
3: let me check with the manager. (Finally gets the green light). "I would have took it for myself if I knew it was that cheap". No ****, douche bag, now cut the friggin steel cable.
mswol767
Boston, MA
Reliance 6 Circuit Transfer Switch Kit with Power Cord
Item #: 182534 | Model #: 30216 BRK
$132.53
Was: $265.05
Save 49%
Ramper
Southern MN
I just picked up some pole barn screws (Hilman calls them tap and seal). They were on clearance for $3.50-5.00 for boxes of 200. I am trying to find them online but I am not having much luck.
Defender Chassis
Williamstown, WV
Thanks OP, got one at the Lowes across town for $127.63 with tax after an additional 10% off. Funny thing is the Lowes down the street had one but it was $8 more.
Found one at a store 1-1/2 hours away for $40. Ordered it and a couple other items I needed to get it over $50 so with tax I was down to $42 with discount for everything. I have this wing joint I like over that direction so I thought I would load up the dog and make an evening of it. Got a call 20 minutes later they had it ready all but the switch. I said just cancel it all and when I hung up I called the other store across town and cancelled that one.
Status
