Lubricating "Particular" Harbor Freight Ratchets
winlinmac
USA
I have a few ratchets from Harbor Freight I want to lubricate as they sound harsh. There is another ratchet from Tekton sounds the same. Anyone knows how to gain access to the internals? We're talking about the swivel head ratchets in particular, which have that tri-wing lever at the head. There are no screws or snap ring visible.
Same question applies to a recently acquired, No Label Wilde 3/8" Drive Ratchet
Thanks
camd64
Cedar Park, TX
Most round head ratchets use a spiral type ring like this
fourtythree
WV
I'd soak it in a glass of ATF overnight. I don't believe you can dissemble that ratchet without destroying it.
gdocktor3
Connecticut
That would probably work, but they can be taken apart. Reference the picture above. Many round head or roto ratchets are held together with the spiral type ring. If you look closely you will see one end of the ring. You can use a small pick or tiny needle nose to pry it back, then you unwind it. Once apart it's actually easier to clean and reassemble than a pear head ratchet. I generally clean the internals with brake cleaner or something similar, then apply a thin coat of Vaseline. There are many different lubes, oils, etc that can be used, but this is something most everyone has and works very good for me. It is also a water repellent and keeps the metals from rusting.
anndel
Hawaii, USA
I did the same with my old Craftsman ratchets - clean the parts with brake parts cleaner then apply a light coat of wheel bearing grease.
zendriver
Indiana
Ratchets are not usually water tight.
Can you dribble a little light machine oil, around the movement?
W
winlinmac
USA
:lol: I should get a better a swivel ratchet if that's the case. Always buy quality from the start. These ratchets sound like a freight train coming to a screeching halt.
