Machining Hastelloy
freudianfloyd
Nowhere
Does anybody have experience machining Hastelloy C-22? I have to make the part in the attached drawing. Machining the outside shape isn't a problem, but parting it at the .040" is proving tricky. I have tried using a slitting saw, but it wore it out pretty quick. The saw was HSS, which I am sure isn't the best material to use, but it was all I had. Anybody have any ideas on how to make this cut? I have looked into wire EDM but the cost was pretty high.
[/URL][/IMG]
Thanks
Jim Pelosi
My shop usually grinds slits like that in titanium and hastalloy. Ceramic tooling is also good for turning hast.
Sent from my SM-G360P using Tapatalk
F
freudianfloyd
Nowhere
How do you mean grind the slits? Do you use a mill with a special type of grinding wheel or something completely different? Please excuse my ignorance.
pxtyson
I do this all the time with a fiber cut off disc on a surface grinder. Simple to do.
