I'd appreciate help with wiring a mag starter, it's an older Furnas three phase which I want to use on a single stage Baldor 5 hp motor (for air compressor) The label inside the mag starter case is faded and torn, but it looks like the pressure switch should be wired to terminals 2 and 3 (?) Terminal 3 is wired to terminal V on the coil and terminal 2 is by itself. I was planning to use LI and L3 for power input and T1 and T3 to the motor. Does this sound right?
Also, the existing 220 line in the garage has me a little puzzled. I see that the ground wire is hooked up to the neutral bar in the panel instead of the ground bar...does this make any difference? The 220 line seemed to work fine with my old smaller compressor that did not use a mag starter (had built in overload protection) Any comments or suggestions would be much appreciated!
