Making do with what I have!
drivesitfar
Sean: your new loft looks pretty stout!!
did you get a deal on your rock since you won't be maybe using it until spring?
i'm pretty cold when it gets below freezing, but it looks like cold weather isn't slowing you down a bit.
keep up the great work.
sean Buick 76
Edmonton Alberta
Yes the rock was a part of a deal last year when I sold a trailer and the guy was short on cash. It’s far more rock than I need but I can sell some off after I’m done. There will be a fire pit, and some other features I will use the rock for.
Sean, You have been busy :pimpflash
Thanks, always busy!
Seems that’s the universal dress code of us Alberta Tradesmen.....blue covvies with stripes! Two pair hanging up in my shop for work down south.
Yes I wear them because they save my cloths from wear and I can easily take them off and go inside without tracking in dust and dirt.
Bob Heine
Boca Raton, Florida
Between the loft and the running gear shelf you have made some outstanding storage space in your garage. I assume you have plans for lighting the underside of the loft.
Looking forward to all your future garage projects, starting with the lift.
sean Buick 76
Edmonton Alberta
Thanks guys! Yes all of the lighting needs to be changed. I will be mounting 4 foot LEDs where each light bulb is. And yes I will add lighting under the loft..:bowdown:
sean Buick 76
Edmonton Alberta
So the 12x8 shed build is underway! Day one worked out well with a lot of progress! I had no friends around to help so the boys and Leanne helped. We had to use some smart thinking instead of pure muscle!
sean Buick 76
Edmonton Alberta
More progress on the 8x12 shed today. Man this this is big! Shingles tmrw. My make shift work platform was too low so I added a lift kit lol!!
Leanne stained the mantle. The mantle was custom built out of cedar by my father and I installed it before they crew added the stone.
Leannes piano room almost setup!
drivesitfar
Sean: while i'm a bit concerned about the footings for your new shed it looks like you are making great progress. did you put wood on the ground or is there cement or gravel we didn't see any pics of? only reason i'm asking is because your shed is about the size of my home (or so it seems) cause it looks huge.
congrats on all the progress in and outside!!
piano music, great kids and a new home and garage sounds perfect to me.
Happy Thanksgiving even if you Canadians don't maybe celebrate it like we do.
sean Buick 76
Edmonton Alberta
At my current job I end up being able to take home extra materials almost each day! 3” angle iron 1/4” thick, and 1.5” angle 1/8” thick.
Shed just needs the doors and details.
sean Buick 76
Edmonton Alberta
The garage door on the 3rd bay was taken down and new raised tracks and side mounted motor.
sean Buick 76
Edmonton Alberta
Better pic of the 1/8 inch thick 1.5” angle
sean Buick 76
Edmonton Alberta
No worries these are good points. I set the shed nice and high off the ground with these doubled up temporary Skids so that when we do the landscaping we can move the shed around, up or down to set it on some sort of final foundation. The ground was frozen and it was too late in the season to start doing the land grading. I wanted the shed set nice and high for now and I hope to get it set about 8” lower than it is but it all depends on the way the land grading works out.
drivesitfar
SEAN: I knew you had a plan for the foundation of your shed and looking forward to seeing how you move it if you do.
I bet once you get it finished it will really open up much needed space inside your garage so you can work inside there while your winter cold months are keeping much activity from going on outside.
cheers!!
rixtrix1
Chandler, AZ (from west NE)
Hi, Sean. Just wondering why you doubled up the joists for your loft and spread them out st 24"centers(or whatever the metro equivalent is). Seems to me that spacing them out closer together (16" centers) would spread out the load carrying capacity and eliminate the need for another layer of plywood to carry more weight without sagging between the joists. JMO
Sent from my SM-J320V using Tapatalk
sean Buick 76
Edmonton Alberta
Hi Ric, I simply had a whole bunch of 3/4” plywood already cut in 24” wide sections so I just did it that way. Yes I agree it would have been stronger the way you describe. Also the plywood should have been turned around the other way do the grain is pointing in perpendicular to the joists. That’s the strongest way. I will just add another layer of 3/4” plywood overtop when I rearrange things next.
The shed is almost done, getting ready to load it up.
rharman
SoCal
Your boys will have some great memories of helping you. I still remember "helping" my dad on stuff that was done 50-60 years ago.
drivesitfar
Sean: that big shed sure looks good from where i'm sitting. I bet you'll probably fill it up quick, but that should free up some needed space in your garage.
nicely done!!!
thieltech
Beaver Dam
great shop build and cars !! , but wow , could they build them houses any closer together ?? if 1 house catches fire the whole towns burnt to the ground
sean Buick 76
Edmonton Alberta
Driving the tracker a lot!
The garage door is raised up 2 feet and now doesn’t push as far back into the bay when it’s up. Perfect added space for the lift. I need to build shims to level the lift. That’s my next move. I still need to replace all the light bulbs with proper lights.
Bought a 83 KZ-550!!!
Merry Christmas!!
sean Buick 76
Edmonton Alberta
I know it’s crazy!!! We literally bought the largest lot available in our town and built it within 4 feet of the property line on each side!
sean Buick 76
Edmonton Alberta
I was planning to setup the lift this week but after a little fender bender my plans changed lol! It was my first accident, no other vehicles involved so it’s not the end of the world. But the hood, grill, bumper and lights added up to a $7500 quote at the body shop! With that quote the insurance company paid me $6000 And let me fix it myself.
$300 for a used white hood (I haven’t swapped it on yet)
$100 for a used grill
$250 for aftermarket headlights
$2000 for both front and rear 250 pound bumpers with LED lights, wiring and winch mount.
So $2650 and some time and I pocketed $3350. I still need to instal the winch, hook up the LED fog lights and put the rear bumper on.
Mr. Roboto
New Hampshire
Your new place is coming along great! Haven't checked in on you in a while, so I am very glad to see that everything worked out with selling the old place in time. That stinks about the truck as well, but looks like you came out ahead!
PhantomEB
Medicine Hat, AB, Canuckistan
I swear your place sure has me thinking of possibilities.
I told the GF if she wants to move I need at least a 4 car garage as I want a street car too.
Now I would consider a 3 car with ceiling like yours as I need it for my off-road truck that’s on 42s. Just need a triple wide driveway that will accommodate 22’ minimum.
sean Buick 76
Edmonton Alberta
Thanks guys! Got the bike home!
drivesitfar
Sean: sorry to hear about your fender bender, but sounds like you didn't get hurt and maybe got to fix a few other things while you had it apart.
here's to a great 2020 for you and your family in your new home.
cheers!!!
sean Buick 76
Edmonton Alberta
cheers!!!
Thanks! Yup it’s better than new! -31 ouch!
sean Buick 76
Edmonton Alberta
Well I need a ton of practice but I’m learning to weld! I have a mig and a tig but I’m starting with the arc welder. The hyd. Ram was worn out on one of my engine cranes so I got a new one but it needed mods to mount where the other one fit.
I welded two junk rims together, I’m mounting those big slicks on them for garage art. I’m using an inner tube because my weld are not air tight lol!!!
