Manageable size steel panel length
Cetnor851
Mi
Finishing off the interior of my barn, 30x40 14’ walls pretty standard. My question is a 28’ piece of steel manageable with a couple guys or 3... I would get a small scissor lift and maybe a guy on a ladder on each end or just order 14’x3” panels and have a small seam in the middle? Perlins are 3’ OC perpendicular to my trusses. Thank you!
u2slow
BC
I'd do 14's because I cant rely on help, let alone good help.
Dragfluid
Pillager, MN
Not enough info. Are you talking about placing the sheets horizontal on the walls? That would look sort of odd I think.
If on the ceiling, they could be handled with the help of a drywall jack. I used 21' pieces on my ceiling that way. Look in my build thread for pics.
Dragfluid
Pillager, MN
🤦🏻****♂️ Yes the ceiling sorry. I didn’t think drywall lifts went up to 14’
Yes, there's an optional extension that you put on. Makes it go up to 16'. I made a rack that placed on top that held the sheet just great. Pics in my build thread. Along with the portable scaffold that I made, it worked sweet. I had friends helping me, but at the end there was like 5 sheets left and I wanted to get it done and I did those by myself. A piece of cake!
finn
The UP, God's country
Some have extensions for extra height. Some guys here have bought a HF unit and made an extension for it.
I searched online for a lift with 15’ capability. It has a shorter mast for regular 8-12’ ceilings and a separate, taller mast to reach 15’, or maybe 16’. I don’t remember if I bought the lift as a package with two masts or if the taller mast was a separate option. I do know it was a separate box, since I kept the box for storage.
A drywall lift is a clunky thing to have around, but in addition to rocking a house and installing a metal ceiling, I have used it to ihang two suspended shop heaters.
C
Cetnor851
Mi
Well thanks for the helpful tips. Anyone know of anyone besides menards that can do custom length panels? I’m in southeast Michigan, I found a guy on delta,OH about an hr and change away that charges a 1.25$ ft for 27” panel
Dragfluid
Pillager, MN
They fold up into a pretty tight area.
I haven't had to worry about mine getting in the way for a while. Another member here borrowed mine 2 years ago and I don't think he's used it yet.:bounce:
Kaizen
New England
Got my Roof from my local lumber yard. They order it and I got it delivered. Took two weeks
jacks2000
Kansas
Also you might start from the back & move towards the doors. That way the overlap of panels almost disappears.
Loose Nut Buster
Near my house in Houghton Lake MI
Where in S.E. MI?
Sounds like Monroe Co. or New Boston pole barn wise anyhow. Some pics of your project would be nice also if possible
I'm from Trenton/Wyandotte area, now living in Houghton Lake..Prudenville 28 yrs
Sent from my SM-T387V using Tapatalk
Innovate1
You are probably going to want more than 2" of overlap. I had mine installed and think there was about 12" of overlap. Two panels about 20' for a total of 39' (building is 40' outside with 6" walls). Main thing with overlap is to make sure both panels are over a truss so the ends of both are fastened down. I got mine from a local lumber supplier in custom lengths.
bradpac
Central TX
Metal building supply or some lumber yard should be able to get them in custom lengths. Get them ordered quick or wait 6 months or better, pricing is going up every week almost right now.
C
Cetnor851
Mi
I’m in Howell, Livingston county. I’ve called a few lumber yards and they all seem to be right about 2.50$-3.50$ a sq ft. Guess I’ll just make the trip down to OH for that much of a price difference. I’ll try and get some pics tonight.
C
Cetnor851
Mi
She’s packed full
NUTTSGT
Northern Central Ohio
Keep in mind, Menard's rolls/stamps/cuts them at their Holiday City, Ohio plant. If you order through your local Menard's they will probably be delivered in 2-3 days.
You could also save some cash and pick them up at the plant yourself. I forget what the savings per ft is.
