Mastercool Manifold Gauge Set Question
Kartman
The ports next to the gauges are used for hose storage. Just plug the high and low pressure fittings into each side when you're done.
W
Wamsutta
Amarillo, Texas
No I don't mean the ports next to the gauges. :)
I mean the holes on the manifold block. If you look to the right of the blue knob, you'll see a shadow of a half circle. Same for the left side of the red knob.
monkeyspanners
Oxford, UK
Fixing holes if the manifold is mounted on a plate or frame. Had a charging station with a vacuum pump, manifold and charging cylinder for domestic refrigerators back when R12 was popular.
