We've discussed this a lot. Moly grease is the best for high pressure screw lubrication- this is what ARP gives you in the little pouches; or they used to. The problem with the tubs of moly grease is it can have 1% moly in it, and they will call it a moly grease. I use the below. It's expensive, but a container will last most of us a lifetime. It's also what you should use on splined driveshafts.
It did not. It was a warranty replacement, so maybe they were supposed to swap it off the old one.
I have a drawer of spare fitting should I want to put one in.
Bought the sealy branded version for about $1000 and it's a beast. Between this the mueller separator the excursion and dodge 3500 was were both done in an afternoon.
Bought the Matco kit for $1000+ It is a beast. Have only used it one time on a mid 2000s 2500HD GMC. Was awkward pushing out (hammer would have been faster) Easy breezy press in. Bad example; my old OTC could have handled easily.
