Matco triple bay. Bought it!
mike93lx
Richmond, VA
Me too. You can pick up old solid core doors for free or nearly so. They make great workbench tops. Just cut them to size and seal the cut edges with whatever old varnish, paint, or shellac you have handy.
Great idea! This is an odd size to match with countertop, so I've been struggling to find something. May be worth a drive to habitat
Pexto
I just cut one a couple of days ago for my new-to-me box here at my 2nd house. Haven't sealed the edges yet. I added a piece of wood in the back to give a small lip so I don't push stuff off the back of the box into the dark abyss.
BTW I looked long and hard for a tool box a couple of months ago here in MA. I paid just a little less for this Mac than you got your new box for. If I had seen that Matco at that price I would've been on it like a rat on a pork chop. Nice snag!
Mr_B
Reading
Other options for top are likes of rubber stable mat, you can set this on ply and finish edges with either likes of black urathane adhesive sealant smoothed out or hardwood/alloy trim .
If you don't over bond the rubber it can be fairly easily replaced if gets too marked up over time, nice surface work with and easy clean, not good for all scenarios but it good on cost and can look like factory option if make bit of effort finishing it nice
mike93lx
Richmond, VA
Right and middle banks are all clean and ready to be greased, I just need to get that and some 1/8 rivets. There are 5 slides that have broken plastic guides... Hoping matco can either replace them or help me with getting accuride to repair. I know that it was suggested to ask for full replacement, but the rest really just needed to be cleaned and will continue to work well for a long time with that done.
The casters feel like they need new springs and a good lube. I don't plan to leave them on, but I want to get them functioning well so I can use them if needed.
1982fxr
Phoenix
Make sure you remind him how far you had to drive as a negotiating point. As if somehow it got farther away after you left home. That’s what I get most frequently. .
if it’s bigger than you expected, feel free to drop it off at my house. I’ll store it for you, no charge.
And then later in the conversation let it slip that you are actually in the area for some completely different reason and we're just around the corner anyway.
rust in the eye
Chicagoland
Rather than breathing all that brake cleaner remove and soak/brush them in a parts washer or just a tub of solvent.
That is a lot of slides to try and spray clean.
Looks like a super deal from here. The nicest thing about a second hand pro box bought right is that If you decide you don't like it you can easily recoup your money. Probably then some in your case due to the added value of making everything work well again.
mike93lx
Richmond, VA
No parts washer here. I'm going it outdoors and am mainly brushing them in a bucket with some brake cleaner at the bottom, then using a spray can to flush the out
I was also doing it outdoors on a breezy day. Other than feeling every cut on my hands when a glove would rip, it went well. Hoping to finish it all next weekend and put it back together
mike93lx
Richmond, VA
For cleaning slides, I picked up a piece of short piece of black sewer pipe and two test plugs from Home Depot. i added some kerosine and sloshed it back and forth to clean the slides, Works well, uses less solvent, and minimizes your exposure.
How long were you letting them soak for?
Mr_B
Reading
+1 on cleaning slides in a plastic pipe, I used diesel in past mainly as had some old diesel with little other use for it.
I soaked them over night but that was because they had a lot of stubborn grunge in them.
this method mixed with a parts washer style scrubbing brush and compressed air work wonders for little cost and minimal solvent exposure .
Bit of brake clean can be handy as a final zap if soak not softened and loosened all of it .
mike93lx
Richmond, VA
It really depends on how dirty the slides are and what lubricants the last owner used. Start at a 5 minutes and see what it looks like
These are pretty bad. The inner cages were completely locked up on many.
I won't say my process was perfect, but its working OK. I don't do stuff like this normally and don't have kerosene or diesel hanging around.
Unfortunately, the slides are discontinued and matco has no solution. I left a message for the warranty department at accuride and am waiting for a call back.
If they can't help, next choice is 3d printing the guides
PCustoms
VT
What are the dims on the slides?
Should be able to find a replacement....
CMB41
california
Here’s the Accuride support site url
PCustoms
VT
I really don't want to replace the entire slide over a little piece of plastic. Plus a 225lb slide is >$100/pair
I'm not sure that little plastic is replaceable though.
Depending on size there are probably other options too. Accuride has horrible consumer pricing IMHO
mike93lx
Richmond, VA
Anything is replaceable if you try hard enough :) it's riveted on, so if I can get or make new ones, I can likely figure something out.
That $100 price was for another brand... Comparable slides from accuride are almost $200.
I'd be surprised if I could get something that has the same attachment method. They slide into two slots and have a rivet on the front. I'm not in a rush, so we'll see. I also don't think the plastic guides are crical to operation, so I could relegate those to less used drawers
larry4406
Northern Virginia
If I recall, @LeonardY recently 3D printed some slide parts....
mike93lx
Richmond, VA
I would assume the guides don't get a lot of load. You might be able to print them from ABS. Nylon would be better. Nylon-CF would be even better.
I was thinking nylon for the durability and slippery-Ness. I figured nylon-cf would be undesireably abrasive. Thoughts on that?
Renegade1LI
long island ny
Nice find on the box! I have been using the citrius degreaser from HF with a small plastic mason tub from HD. Makes a good poor mans parts washer & it cleans pretty good. For the top see if you can find some 1" baltic birch plwood 13 - 17 plies, machines well & makes a good shock absorbing top. Could always go with home depot butcher block or look on MP for someone selling a butcher block table, they usually go cheap.
mike93lx
Richmond, VA
Thanks. It's an odd size to use a countertop. 76x26.25 so an island top is deep enough, but most stop at 72".
If I can find a deal on a solid core door slab, that may work well, but I'm keeping an eye on MP for something else. Someone locally is selling large sheets of stainless. 1/8" on top of 3/4 ply could work well.
LXCam
I had some scrap left over from a couple tables. So I end butted both sides perpendicular to the center.
Also I consider this top a consumable so it gets used big time and every few months I’ll fill the nicks and drill holes and give it a lite sanding. Right now is juuust about that time 😉
mike93lx
Richmond, VA
I may do something similar as a buddy has scrap countertop, but it would require 4 pieces. There are solid core fire doors on MP for $100 and less, which would let me do it at once and even oversize slightly to get a little more work surface
mike93lx
Richmond, VA
Menards has what you need but but you don't have Menards, I believe.
Yeah, no menards within hundreds of miles.
Around here, I'd get "butcher block" at floor and decor, but they don't have the right size.
I really tight on height... Tight enough that the extra inch thickness of a door/counter vs a sheet of ply could be a problem, so I need to measure to confirm. This box will sit out in the middle of my garage, under the overhead door, and I want to build a hutch to go over the printers. Need to measure this weekend to confirm
AEAdam
SE PA
Good luck on the slides. Heard you mention grease. Please think that over. I think dry film lube could be a better solution. I know some prefer W-40. Pretty sure you don't want grease.
mike93lx
Richmond, VA
Accuride says to use wheel bearing grease
Why would anyone use wd40? It's not a lubricant
AEAdam
SE PA
Good Morning Mike!
All non drying greases and oils will attract dirt. Many of us do not maintain/service toolbox slides. So they get nasty and start moving slowly.
A better question is why put anything on them at all?
WD40 is absolutely a lubricant. It's just not a great one. WD-40 is essentially a light mineral oil, not unlike Kerosene in an aerosol spray bottle. Internet lore says "it's not a lubricant because WD stand for "water dispersant"". That's true. It was marketed that way, but that doesn't change what it is.
3 in 1 oil came from my home state of NJ! The 3 is "cleans, lubricates, and protects" just like the "special" CLP Breakfree oil you can pay crazy money for in a gun store. It too is just mineral oil.
You can use 3 in 1. Everyone should have 3 in 1 in their toolbox. I think WD-40 is probably used by guys who occasionally reapply it. Maybe the aerosol helps dislodge old dirty oil. And it helps you get oil in spots where you need it.
I'm sure some here would recommend SuperLube. SuperLube is really not an amazing grease. There are plenty of better greases. The advantage of SuperLube is that it's a full synthetic (and its conveniently available, where some industrial greases are only sold in tubes or 5 gallon tubs). So your drawers won't be stiffer in freezing temperatures. But if that's not a concern, then any other grease would work fine. If your box is essentially stored inside, and doesn't get exposed to any elements, dust, pollen, saw dust, grinding dust etc etc, then it probably doesn't matter what you use to lube your slides.
To be honest, dry film lube is probably the "right" thing to do. WD-40 makes a lot of sense when you think about reapplying it to flush debris out. If the only thing WD-40 did was blow out dirt, it would be worth it. But that's not all it does. It will leave an oil residue behind.
PCustoms
VT
Speaking of Internet myths...
@mike93lx new slides have some sort of white grease.
**** I've saved (ironically WD-40 breaks down crusty/dirty slides well) I've used a dry lube. Used to get the Teflon one, since that's pretty nasty I switched, would have to check can. Grease collects way too much sawdust for me
