Material Handling straps etc
iajonesy
Iowa
"LiftAll" are the best slings out there with dozens of options in styles, load range, materials,etc.
Mike
matt_i
McMaster Carr I believe carries Tuflex roundslings. Have used them on a hundred or more personal and professional rigging and lifting jobs with no issues.
With any woven product, one must take care to protect the sling from chafing over sharp metal edges. Also not appropriate to ground the load on top of the sling and then try to rip it out sideways....
Other really good things to have are anchor shackles with screw-pins. I always buy them in pairs.
My free advice is to resist the temptation to buy eyebolts unless its used on a single vertical pick like an electric motor and instead buy swiveling hoist rings that align with the load path and don't have a fragile neck to bend or break.
Past that, one can make a lot of attachments with hot-bending and drilling flat bar plus typical Gr5 bolts.
Paul_The_Builder
Dallas, TX
Northern Tool and Equipment has a pretty good selection for a brick and mortar store. I trust their equipment more than HF... I use Northern Tool straps for towing my cars and motorcycles and they do well.
speed bump
Butte Montana
Amazon has an okay selection. Personally I quit buying stuff I have to trust from them a few years ago though. Now I buy them at the local industrial supply place.
txvwnut
Bedford, Texas
Is there a rigging supply company near you. I’ve got a Delta Rigging down the street from me and there prices are very respectable.
Badger 13
Northern Idaho
Zips/AW Direct is a great place for items like that.
Zip's AW Direct - Towing Equipment & Accessories
Ad·www.zips.com/
Zip's AW Direct has the largest selection of towing accessories & repair parts. Shop now. Custom Tow Trucks & The Largest Selection of Equipment, Accessories & Replacement Parts. 400+ Brands. 40,000+ Items In-Stock. Custom-Built Wreckers.
930dreamer
Amarillo,TX and Stinnett,TX
Ad·www.zips.com/
The body shop that replaced my door glass had a AW Direct catalog in the lobby.
