rburke65
I vote fir white metal. Lighter than OSB and ya shoot your screws in and your done!
I wasn't sure if I should have started a new thread or not, but this thread brings up a question for my ceiling. I have a 30x40 pole barn with the trusses 8' on center. I think I am going with the metal panels but I would have to run 8' 2x4's between the trusses and my concerns are if the trusses will be able to handle the weight of the metal, insulation, and the 2x4's without sagging in the middle and would the 8' 2x4's be able to handle the weight? Thank you
I'm on the North end of Colorado Springs. Any suggestions for buying interior metal for the ceiling of my 40x56 pole barn ? (There's no Menard's around here.) I'm about ready to "bite the bullet" and spend the cash, but not sure where to go. Menard's can ship it, but it adds a bit to the cost...
Maybe someone has bought some locally ? I've got a 16' flat bed trailer, so I could go pick it up. Thanks for any suggestions...
Also trusses are 4' on center. I was planning to install vapor barrier and blow in insulation on top. It sure looks like the metal would seal well, is a barrier still required ?
How to you gents put up fluorescent fixtures with a metal ceiling? Just drill a hole and use toggle bolts or is the metal too flimsy, meaning each fixture must be screwed into a truss bottom?
I know this is super old but hoping you're still around. I am about to use corrugated on my garage ceiling but I keep hearing I need to install foil faced insulation between my rafters before doing so. I live in Michigan.
I keep hearing from buddies that there will be condensation if I don't use that foil faced insulation board. I really don't want too to be honest.
Thoughts?
Yours looks great btw
Just get some cellulose blown on top of it. Are you planning on insulating at all?
I stuffed 2 1/2" of styrofoam between my truss cavities, the Visqueen, thenthemetalliner panels, and the blown Fiberglas on top of the styrofoam. I'm in Ohio.
So, if I understand what you are saying....
You have none of the "bubble wrap" type insulation (really just a vapor barrier) up already? (between the top of the truss and the tin) This is most common around here... as it keeps your roof from "raining".
I put the tin directly to the bottom of the trusses. I then had open cell foam sprayed on top of the tin... It was comparatively priced to using the blown in paper stuff... AND I did not have to touch a thing.
IF you have nothing up at all..... are you planning on heating or cooling the space?
IF you have nothing, I would put up the 1/4" foam board they commonly use under siding.
http://www.homedepot.com/p/Owens-Co...1-Fanfold-Insulation-Sheathing-21UM/100320301
This will prevent condensation on your tin. IF you want to insulate later, you have the vapor barrier basically.
Wags
Thanks... I am happy with how mine turned out.
If you want any tech tips... just ask or pm me.
So as of now it's just open rafters. Nothing in between or on them at all. I was going to install the corrugated metal on the rafters and call it a day until I discovered I needed some type of "vapor barrier" to prevent condensation.
So I am trying to find something relatively easy to get the tin up quickly (winter is coming) and then maybe insulate later? I do NOT plan on cooling the space, but I may install a small ventless wall heater in case I need to be out there in the winter months for any extended time.
So what you're saying is to install rigid foam boards between the rafters or just lay it on top of the metal as I'm screwing each metal sheet to the rafter?
Would tacking up a visqueen plastic sheeting material then installing the metal work until I could get something blown in there?
Thanks again I might bug you for a while haha
Metal buildings, or buildings with steel walls/ ceilings will block most signals... not totally.... but to make it damn near useless.I read here on another post about cell phone service and wi-fi service being an issue with the interior walls and ceiling of a shop being lined with steel. Anyone have this problem? I'm leaning towards steel myself but may consider something else if this is an issue. BCD.
i used 2in. thick styrofoam from home depot. they come in 4x8 sheets. a one man job to install as the sheets are very light & easy to handle. they are already white so no painting required plus it has an insulating factor. easy to cut with a hand saw also & moisture wont bother it. just my .02
My garage currently has a drywall ceiling that finished by the previous home owner. Unfortunately, they didn't know what they were doing with drywall. All of the drywall tape is coming down and it is a mess. I'm seeking advice. I would like to put up metal on the ceiling. Any issues with me just putting the metal up over the existing ceiling and using long enough screws to extend through the metal and drywall into the wood on the bottom of the ceiling joists? I really don't want to mess with taking it all down first.
Has anyone reading this thread ever used soffit material on their interior ceilings?
I was recently walking through the Tampa airport and noticed a noise canceling style ceiling, I was amazed how quiet it was in the terminal considering how crowded it was over thanksgiving.
This was the closest match I could find.
https://www.lowes.com/pd/Georgia-Pacific-12-in-x-144-in-White-Pebble-Soffit/50106928
Thinking about stapling a thin layer of woven insulation over the OSB of the ceiling follow by a product like this.
Pros -light weight, easy install, no painting required
- no cell phone interference
- noise cancelation??
Cons- cost ?
- insulation fibers coming through the holes & getting on cars?
Thoughts?
I used a drywall lift to raise the panels, and a 10' step ladders. Did it myself with 13'4" ceilings. I was able to raise and position the panels, climb the ladder, final alignment and shoot the screws. DONE! No painting, joint compound, primer, 2 top coats, sanding. Screw n done. Love it. And, if you really needed to, you could remove a section to have access to above the ceiling.....do any magic, and reinstall the panel.
