You will be fine
The bolts are 19mm and I have a breaker bar. Its a bit thicker than most of the other breaker bars I have seen. But its a cheapie. So I might just invest in a breaker bar I feel more confident in and at least a 19mm 1/2in drive socket. Just to be safe. I will be using a Gearwrench 1/2in drive 20-250ft lb torque wrench.
I appreciate all the help! Im always apprehensive to make a first post on forums not knowing the crowd. I think ill stick around here tho. Seems like a great bunch or very knowledgeable people here!
You're on track here if you're worried about 3/8" not handling it. You can get a 19mm impact socket and 1/2" breaker bar at HF for probably less than $15
Hey guys, I plan on doing some work on my car. The most torque any of the bolts/nuts will be getting is around 130in lbs. Will 3/8in craftsman sockets be able to handle that much torque or should I go with 1/2in drive sockets?
I was trying to get something up to 75 ft. lb. with a Craftsman 3/8" drive chrome socket in 15mm. but it split/busted just before the torque wrench would have clicked-but that socket was broached off-center and very thin at the corner that cracked--local Sears was still in business in those days and I exchanged it for a good one- 1980 Citation had engine cradle or subframe with 15 mm. headed bolts that compressed rubber "cushions" -keeping them tight tended to keep the engine/powertrain from moving so much when you went from pulling to coasting-also got myself a 15 mm. Impact 1/2" drive socket at Sears after that-
I use my 12pt STAHLWILLE 21mm socket on Teng-Tools 75mm extrension to remove wheels on cars + 500mm Teng-Tools extension bar + Teng-Tools T Bar Adaptor 1/2in Female 3/8in Male. All stuff 3/8" drive. Works good.
If manufacturer made socket 21mm, or 19mm or even 24mm with square 3/8", it's MUST do the job! I believe square 3/8" MUST handle 200nM (147.5 foot pounds) without any problems.
If you can fit socket on bolt, use it, no matter it's 3/8" or 1/4" etc. If it's splits - it's garbage. If splits square - it's too big load or... it's garbage breaker bar, ratchet etc.imho
