In a previous post I was asking for advise finding a local installer for a MaxJax, because I was not sure about the concrete. I finally got in touch with Garage Equipment Supply and they hooked me up with a local installer who retrieved the lift from the shipping depot, brought it to my house and installed it.
This particular installer prefers to use bolts instead of the supplied anchors because he felt they were safer. I agreed to that because I was more interested in safety than convenience and with my tiny 12 x 24 foot garage, I don't really have much room to store the columns anywhere else anyway. Turns out the concrete was good after all, with 4-1/2 to 6 inches of depth, and the installer thought it might be fiberglass reinforced from the way it drilled.
So the columns are bolted down and there they stay. I could move the columns if I wanted to, but we wound up locating them near the walls at a spacing of 135 inches. At that width, I can walk around the car easily since my normal parking position is about 2 feet back from where I position it to be lifted.
I'm a little concerned about such a wide column spacing, but I contacted Dannmar and they assured me it was okay since the lift arms aren't fully extended when lifting my Cayman (see photo below).
I should note that one year ago, this was a one-car carport. The space is well insulated, with a 9000 BTU heat pump/air conditioner. It has an 8-foot ceiling, so prior to installing the lift, I replaced the track garage door opener with a Liftmaster 3800 jackshaft opener, to get adequate clearance. The installation of a lift marks the completion of my carport-to-garage conversion project.
The only problems I had with the MaxJax were 1) the usual problems synchronizing the two cylinders, but I finally got that sorted out; 2) paint and metal burrs in the holes in the lift arms where the large pin goes; and 3) a frustrating leak in the ATF reservoir around the drain plug. I cranked down on the plastic drain plug as much as I dared. If it continues to leak, I will RTV the sucker.
Here are a couple of photos taken before I moved all the shelves along the right side back.
When you are limited to such a small work area, you have to be very creative about how you use the space. The MaxJax is perfect for this garage. As you can see, I don't have space for a big workbench, but I will build a more proper bench soon. I wish I had the space for my other two workbenches and my big toolbox, but a tiny garage beats a carport any day.
